Results 1 to 7 of 7
Thread: Demolished Patterns
    2007-02
    41
    Default Demolished Patterns
    I need to show a Diagonal down-small pattern on top of objects to be Demolished in the current Phase. So, I went to the Phasing dialog, and then to the Graphics Overides tab. I adjusted the Demolished Surface Pattern to show Diagonal down-small.
    Works great, right? Well, sort of. See attached image.
    A bit more background: in Object Styles, Plumbing Fixtures are set to line weight 1, Ducts are set to 5, and Duct Fittings are set to 5.
    Does anyone have a good plan for making the Demolished Pattern look more consistent across all Categories?
    Oh ya, good morning all. Just another Revit MEP day.
    Thanks for the conversation, as always.
    Chris
    2006-10
    236
    Default Re: Demolished Patterns
    Kinda hard to see your attached image - do you have a close-up?
    2007-02
    41
    Talking Re: Demolished Patterns
    Ha Ha. No, I don't have a better image, and I guess you can't see anything in the one I uploaded. Sorry. I can recreate it later this afternoon and repost.
    Chris
    2008-02
    Austin, TX
    210
    Quote Originally Posted by ArchWestCY View Post
    Chris
    The Snipping Tool built into Windows makes taking screenshots really easy, and you can mark them up too. It's under Accessories somewhere.
    2002-06
    North Central CT
    1,108
    Or just, I dunno.... zoom in!
    Matt
    2005-08
    11,000 feet atop a chute
    1,001
    If you squint really really hard than you can almost still see nothing.
    I'm almost 100% sure, lets say 99% that the patterns are overridden by the categories line weight.
    You can create a filter and override those phases. Your filters will determine the line weight. I think. I don't have time to test.
    2007-02
    41
    Here is an updated image.
    I think Jrobker is right on track. Does anyone else have another idea?
  1. Why can't drafting patterns act like model patterns for cuts?
    By AP23 in forum Revit Architecture - General
    Last Post: 2016-10-26, 03:59 PM
  2. 2015: create/ convert hatch patterns (.pat) to revit fill patterns
    By jledgewood in forum Revit Architecture - Tips & Tricks
    Last Post: 2015-06-01, 11:48 PM
  3. I wish for the ability to use model patterns as cut patterns for materials.
    Last Post: 2015-05-07, 02:49 PM
  4. Nomenclature: patterns in the model vs patterns in the view
    By ron.sanpedro in forum Revit - In Practice
    Last Post: 2010-01-28, 12:10 AM
  5. Demolished walls in ADT
    By jarkko.rasanen in forum ACA General
    Last Post: 2006-09-25, 03:22 PM
