Thread: normal vs. pattern based curtain wall panel
    All AUGI, all the time Ning Zhou's Avatar
    2006-08
    599
    Default normal vs. pattern based curtain wall panel
    played a bit w/ this new pattern based stuff along w/ concept mass, adaptive component, etc., great tool for Concept design, but just wonder how this can be useful in later design stage, like SD / DD / CD?
    for instance, seems pattern based panel cannot be used in normal curtain wall (?), so how can you get your project curtain wall (using normal panel) to match the conceptual mass curtain wall (using pattern based panel)? as I import the conceptual mass curtain wall into the project every thing looks great, except it’s all a mass, i cannot figure out the way to convert to normal curtain wall so it can be more easily handled at later design stage.
    maybe i missed something simple or just a limitation? thanks.
    Revit BIM Consultant Alfredo Medina's Avatar
    2008-05
    Miami, FL
    999
    Default Re: normal vs. pattern based curtain wall panel
    I have been studying this topic, and this is what I can tell you (so far), (stick around):
    When we apply an adaptive component pattern to a divided surface in the conceptual design environment, and then we load the mass family into the project, the surface keeps being a mass, not a curtain wall element; however, we can still schedule their panels as Curtain panels. These are some of the things that can be documented:
    • Number of Curtain panels, and their marks.
      Area of each panel.
      Dimensions of each panel (with reporting parameters). (See illustration).
    Even though the panels are recognized as panels, the division between panels are not recognized as mullions, but there might be a way to schedule these mullions. I don't know yet. The area of the whole surface is available through a mass schedule, since it's not a curtain wall element but a mass.
    2006-08
    599
    thanks Alfredo, confirmed my understanding for this great yet limited tool.
    i guess you have to model "mullion" stuff within that mass or adaptive component family before loading into project (?), but how to schedule these "mullions"?
  1. 2012: Curtain Panel Pattern Based.rft Question
    By Jarod in forum Revit - Conceptual Design Tools
    Last Post: 2012-03-12, 06:42 PM
  2. Replies: 10
    Last Post: 2010-08-25, 12:57 PM
  3. Curtain Panel Pattern Based
    By PaperStreet SoapCO in forum Revit Architecture - Families
    Last Post: 2009-06-08, 08:07 PM
  4. Missing pattern based curtain wall panels (2010)
    By AP23 in forum Revit Architecture - General
    Last Post: 2009-04-19, 08:10 AM
  5. Frit pattern curtain wall panel
    By Gatchy in forum Revit Architecture - General
    Last Post: 2008-10-20, 07:19 PM
