Thread: Custom duct accessory does not break into ducts
    2002-06
    North Central CT
    1,108
    Default Custom duct accessory does not break into ducts
    I'm trying to create a simple Phoenix Valve as a duct accessory. I've got it set to 'break into' (I used one of the OOTB filter panels as a guide) but it won't. When I place it, the duct highlights as if it's going to attach to it, but when I actually place it, it shows up BELOW the duct. I've attached the family (2009). Any thoughts? Suggestions?
    Thanks in advance!
    Matt
    2009-07
    KC
    338
    Default Re: Custom duct accessory does not break into ducts
    it seems to work fine in 2011...but not in 2009. I know that's no help but interesting.
    2002-06
    North Central CT
    1,108
    Yet another reason for us to upgrade (too bad we're at the mercy of the archies). :\
    2010-02
    185
    It looks like there weren't ebough constraints for Revit to place the valve successfully. Changed fam type from damper to breaks into. Put duct connector contraints, and some geometric constraints, loaded it, and poof. It worked.
  1. Replies: 0
    Last Post: 2014-12-01, 03:40 AM
  2. Revit MEP Duct Accessory Scheduling
    By boey1219 in forum Revit MEP - General
    Last Post: 2014-05-02, 12:29 PM
  3. 2012: Duct Accessory and Insulation - Electric duct heater
    By tim.winnington205328 in forum Revit MEP - Families
    Last Post: 2012-07-27, 05:48 AM
  4. Duct Accessory Problem- Volume Dampers
    By krylance in forum Revit MEP - General
    Last Post: 2008-12-18, 06:33 PM
  5. Duct Accessory
    By resident777114711 in forum Revit MEP - Wish List
    Last Post: 2007-01-22, 08:25 PM
