Thread: Cannot Publish to PDF from DWG TrueView 2011
    I could stop if I wanted to The Sweg's Avatar
    2003-09
    Amish Country
    205
    Default Cannot Publish to PDF from DWG TrueView 2011
    I am trying to Publish to PDF from DWG TrueView 2011 and cannot get anything to work. I'm using page setups with all kinds of different pc3 files associated with them to see if any of them work. Nothing. I can publish just fine from AutoCAD or AutoCAD LT (2011) with the same exact page set ups.
    Is this a known issue? Does anyone have a way of successfully doing this? I hate to put AutoCAD on user's computers just so they can publish, which they used to do just fine in DWG TrueView 2008!
    Thanks for any help!
    Choose not to be offended.
    Administrator RobertB's Avatar
    2001-08
    Dallas TX USA
    5,829
    Default Re: Cannot Publish to PDF from DWG TrueView 2011
    Are you using 2011's DWG to PDF.pc3 file?
    R. Robert Bell
    Design Technology Manager
    S P A R L I N G
    Opinions expressed are mine alone and do not reflect the views of Sparling.
    2003-09
    Amish Country
    205
    OK, so maybe either I'm really stupid, or you're just a freakin' genius (or both). I was NOT, in fact, using the 2011 DWG to PDF.pc3 file. So, after setting that up, of course.....it worked!
    Thank you very much!
    I can always count on you guys here at AUGI!
  1. Publish error Page Setup works Publish won't
    By jmagarolas962356 in forum AutoCAD Plotting
    Last Post: 2011-02-10, 11:29 PM
  2. ASD 2011 - Reinforcem​ent / DWG TrueView 2011 wrong conversion.
    By abbakeer in forum AutoCAD Structural Detailing
    Last Post: 2011-02-06, 05:46 AM
  3. Publish in DWG TrueView
    By nextvkin in forum AutoCAD General
    Last Post: 2010-09-22, 04:08 AM
  4. 2011 can only publish 2011 NWD files?
    By cjehly in forum NavisWorks - General
    Last Post: 2010-08-23, 07:50 PM
  5. only publish the first drawing in the publish list
    By bigpigdig in forum AutoCAD Plotting
    Last Post: 2006-08-04, 12:16 AM
