Results 1 to 10 of 17
Thread: Add Boundary to TIN Surface
    Moderator BlackBox's Avatar
    2009-11
    2,397
    Default Add Boundary to TIN Surface
    I am stuck trying to determine the proper syntax and arguments needed to programmatically add a polyline boundary to a TIN surface.
    I have successfully been able to access the surfaces collection, create a new (empty) surface, add points to that surface (via points file in the ..\Dtm\<SurfaceName>\ directory), and build the surface.
    ... But I still need an outer-boundary. Can someone help me out? I cannot find documentation for how to properly invoke this method.
    This is the method I have been experimenting with (unsuccessfully):
    ;; Add boundary to surface
           (vlax-invoke-method
             (vlax-get (vlax-get new_aecSurfItem 'inputs) 'boundaries)
             'add
             ;| (vlax-safearray->list
             (vlax-variant-value
               (vla-get-coordinates
                 (vlax-ename->vla-object eName)))) |;
             ;;eName
             "Boundary0"
             "Outer"
             "Yes"
    This is the error message I get, in the current configuration:
    lisp value has no coercion to VARIANT with this type:  #<VLA-OBJECT
    IAcadLWPolyline 224bcb04>
    When done manually (i.e., right+click on the boundaries node within Terrain Model Explorer, select Add Boundary Definition), this is a copy of the command line:
    Command: _AECTREEMGREVENT
    Select polyline for boundary:
    Boundary name <Boundary0>:
    Boundary type (Show/Hide/Outer) <Outer>:
    Make breaklines along edges? (Yes/No) <Yes>:
    What am I missing!?
    Edit: I am using AutoCAD Civil 3D Land Desktop Companion 2009
    "Potential has a shelf life." - Margaret Atwood
    Houston
    7,520
    Default Re: Add Boundary to TIN Surface
    Check your syntax.
    The HELP file says...
    RetVal = object.Add(Type, bIsBreakLine, Coordinates[, Description])
    So the arguments to the 'Add method should be something like
    PHP Code:
    :vlax-true
    (vlax-get-property (vlax-ename->vla-object eName"Coordinates")
    "Boundary0"
    2009-11
    2,397
    Check your syntax.
    RK, you're the man! That is exactly what I was missing!!
    Can you please tell me where you found this syntax listed?
    Houston
    7,520
    Quote Originally Posted by RenderMan View Post
    (strcat
       (vl-registry-read
          (strcat "HKEY_LOCAL_MACHINE\\" (vlax-product-key)) "ACADLOCATION")
         "\\Help\\landauto-reference.chm"
    2009-11
    2,397
    You have much knowledge, RK.
    Cheers!
    2009-11
    2,397
    Thanks to your help, RK, I've successfully been able to add the boundary to the surface.
    However, the boundary is not acting on the surface properly.
    When viewed from Terrain Model Explorer, the boundary is correctly set to Outer, and set to Trim, but the boundary does not trim the surface at all.
    I've played with the various 'type' arguments when adding the boundary (0=Show, 1=Hide, 2=Outer, etc.). I've attempted to build the surface with just the points file, then add the boundary and re-build... no change. I've also attempted to add the boundary coordinates as a contour in lieu of the points (outside of the polyline), and this results in surface points off in space.
    Here is the code I've been using to add the points file, and boundary:
    ;; Add points file to surface
    (setq pnts
      (vlax-invoke-method
        (vlax-get (vlax-get surfObj 'inputs) 'pointfiles)
        'add
        textFilePath))
    (setq bnd
      (vlax-invoke-method
        (vlax-get (vlax-get surfObj 'inputs) 'boundaries)
          'add
          ;;0                                                 ; Show
          ;;1                                                 ; Hide
          2                                                   ; Outer
          :vlax-true
          (vlax-get-property lineObj "Coordinates")
          "Boundary0"))
    ;; Build surface
    (vlax-invoke-method surfObj 'build)
    Something that caught my eye when reading through the Land Reference, is that the coordinates for the boundary should be in "Easting, Northing, Elevation format." The polyline I am selecting is at elevation 0. I've tried (vla-put-elevation lineObj basnElev) prior to (vlax-get-property lineObj 'coordinates), but the elevation is not included in the resulting points list.
    Could this be the reason for my boundary not trimming the surface?
    If so, how do I make pointList a variant of safearrays?
    (foreach pt (vl-remove-if-not
                  '(lambda (x)
                     (= 10 (car x)))
                  (entget eName))
      (setq pointList (append (list (cadr pt) (caddr pt) basnElev) pointList)))
    Any help would be greatly appreciated.
    AUGI Addict alanjt's Avatar
    2008-02
    1,073
    (defun AT:PointList->Array (lst)
      ;; Convert point list (must be appended first) to array
      ;; Alan J. Thompson, 09.16.09
      (if (vl-consp lst)
        (vlax-Make-Variant
          (vlax-SafeArray-Fill (vlax-Make-SafeArray vlax-vbDouble (cons 0 (- (length lst) 1))) lst)
    (defun AT:GetVertexPoints (e / p l)
      ;; Return point at each vertex of LWPolyline or Polyline
      ;; e - LWPolyline, 2DPolyline, 3DPolyline
      ;; Alan J. Thompson, 09.20.10
      (if e
        (repeat (setq p (1+ (fix (vlax-curve-getEndParam e))))
          (setq l (cons (vlax-curve-getPointAtParam e (setq p (1- p))) l))
    eg.
    (AT:PointList->Array (apply 'append (AT:GetVertexPoints (car (entsel)))))
    Good for *Polylines (vla-object or ename).
    Civil 3D 2011|2012 ~ Windohz 7
    Dropbox | finding the light…
    2008-02
    1,073
    Actually, this will keep you from having to append the point lists.
    (defun AT:VertexPointsForArray (e / p l)
      ;; Return point at each vertex of LWPolyline or Polyline (in single list)
      ;; Alan J. Thompson, 09.24.10
      (if e
          (setq l (append l (vlax-curve-getPointAtParam e (setq p (1- p)))))
    2009-11
    2,397
    Quote Originally Posted by alanjt View Post
      (if (vl-consp lst)
        (vlax-Make-Variant
    Eureka!
    That was exactly the problem with my surface. Each point along the boundary, requires the surface elevation.
    This is the first time I'm having to push data into a safearray/variant, as I am normally pulling the data out into a list (i.e., coordinates).
    While I was unable to code this myself, I am at least pleased I was able to deduce the problem myself. It feels good to know you were 'at least' on the the right track.
    I cannot thank you enough for your help, cheers!
    2008-02
    1,073
    Good deal. Can't wait to see the finished product.
  1. Surface Boundary Issues
    By clarkl in forum AutoCAD Civil 3D - General
    Last Post: 2007-12-11, 03:36 PM
  2. Surface boundary causes surface errors
    By cblendermann.91943 in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2007-02-23, 11:57 AM
  3. Topo Surface Boundary
    By Batman in forum Revit Architecture - General
    Last Post: 2005-10-15, 10:33 AM
  4. Boundary intersects itself. Surface boundary could not be applied.
    By brian.59027 in forum Land Desktop - General
    Last Post: 2005-10-13, 02:35 PM
