Thread: Mouse Wheel "Pan" Function Is Missing
    2006-04
    (getpoint "Anywhere on the Enter Key =>")
    1,160
    Default Mouse Wheel "Pan" Function Is Missing
    The mouse wheel "pan" function lost after moved to a new machine.
    I have checked the "options", "cui" and "mouse" in the control panel but found nothing to do with.
    Win7 pro
    AutoCAD 2011
    Your helps are much appreciated.
    2010-08
    11
    Default Re: Mouse Wheel "Pan" Function Is Missing
    Make sure your mouse wheel is assigned to "middle button" in the control panel (it's not by default if you're using Microsoft Intellipoint or Logitech SetPoint mouse drivers)
    2006-04
    1,160
    Yes, I find it.
    Thanks for your help.
  1. Mouse Center Roller wheel - doesn't "PAN" anymore
    By marvin.r in forum ACA General
    Last Post: 2010-06-14, 06:14 PM
  2. Mouse wheel zooms only when holding "ctrl" key
    By matthew.kimball in forum AutoCAD General
    Last Post: 2008-06-03, 03:51 PM
  3. Replies: 4
    Last Post: 2006-11-10, 03:50 PM
  4. Can I program the "Back" and "Forward" mouse buttons for ADT3.3?
    By jhohman in forum AutoCAD Customization
    Last Post: 2004-12-29, 06:57 PM
  5. Missing "inches" "mm" in Plot menu 2005
    By jfranco in forum AutoCAD Plotting
    Last Post: 2004-11-05, 10:10 PM
