Thread: Rotate Project North
    2006-09
    257
    Default Rotate Project North
    Hi,
    We have a project that has been modelled in True North (with origin moved within 2Km radius). Users have been using scopebox to get orthogonal views (instead of project north). So when I go into a plan view and switch off scopebox everything shows in True North. When I change Orientation to Project North the plan stays at the same orientation.
    The angle between Project North and True North is 37.580.
    When I go into "Project North" orientation and Roate Project North by that angle it rotates True North as well.
    I also tried linking this central file into a blank project file in which "shared coordinates" are established and moving/rotating central file to its location and "Publish Coordinates" to central file hoping that will push coordinates to central file. But it doesn't.
    I have tried all options but it doesnt seem to work. Can someone please help?
    The project is in Revit 2011 with workset enable. I am working in central file to change this orientation.
    Thanks in anticipation.
    Regards
    AUGI Addict andrewg's Avatar
    2003-05
    Waterville, Maine
    1,748
    Default Re: Rotate Project North
    Might be better to turn on a crop region, select it, and rotate the view, for the views you want orthoganal. Take a look at this thread.
  1. Rotate Project North
    By trialbyfire in forum Revit Structure - General
    Last Post: 2011-07-18, 12:51 AM
  2. Rotate Project North does not rotate the Design Options
    By weston in forum Revit Architecture - General
    Last Post: 2009-11-05, 04:22 PM
  3. True North Rotate and Project North Alignment
    By Firmso in forum Revit Architecture - General
    Last Post: 2007-06-13, 05:11 AM
  4. Rotate to Project North/True North?!
    By jond in forum Revit Architecture - General
    Last Post: 2006-04-13, 01:49 AM
