Results 1 to 6 of 6
Thread: systems and performance
    2009-01
    345
    Default systems and performance
    Our model has become un-manageably slow and I need to figure out why. It seems to have gotten a lot worse since putting a lot of stuff onto systems. I noticed that a warning for the default systems will pop up saying something to the effect of "you have over 50 things on this system so we will not do calculations because it will take too long." I don't need revit to do any calculations for me on these systems, is there a way to turn the calculations off on the less-than-50 systems? Or is there anything else I should look into to improve performance related to systems?
    I could stop if I wanted to gvluisi's Avatar
    2009-05
    Pittsburgh, PA
    227
    Default Re: systems and performance
    No help here, just commiseration. Currently working on a 12 story project, M, E and P and we are well over the 50 thing systems error but do not experience the kind of slow down I think you are experiencing. When I have the System Browser up, things get really slooooow. When I close the browser, things get quicker.
    We have Arch & Struct models linked, Worksets enabled with about 5 or 6 users.
    MEP 2010, Windows Vista Business, Dell Precision T3500, Intel Xeon CPU, W3570@3.20GHz 12 GB Ram - 64 Bit OS
    2008-03
    39
    I don't think anyone has come up with a solid reason why performance instantly tanks on some projects at a certain point. I have used systems and have had other projects that I don't use systems...regardess I've had the slow down happen at some points and not on every projects. It really doesn't seem to be inconsistent.
    I could stop if I wanted to sgermano's Avatar
    2007-12
    Las Vegas, NV
    236
    Check your families. If you have any families with cad geometry in them it kills your models.
    I could stop if I wanted to Simon.Whitbread's Avatar
    2003-05
    Auckland NZ
    347
    Quote Originally Posted by sgermano View Post
    ...cad geometry in them it kills your models.
    CAD geometry of any description, linked, imported, not just hosted in families
    Its nasty!
    Simon Whitbread
    Revit Specialist, Auckland, New Zealand
    about.me/simonwhitbread
    "The distance the shotput goes, depends upon the effort that you PUT INTO IT"
    100 Club jseck's Avatar
    2009-06
    Missouri
    111
    Overly detailed families are a performance killer as well.
  1. Performance
    By luc.hamel in forum Revit MEP - General
    Last Post: 2011-06-21, 07:20 PM
  2. Replies: 3
    Last Post: 2010-04-06, 02:32 PM
  3. performance???
    By dyanosik in forum Inventor - General
    Last Post: 2009-01-14, 10:51 PM
  4. CAD performance - what does it take?
    By dhallett in forum ACA General
    Last Post: 2008-05-15, 10:55 PM
  5. DWF Set performance
    By sbrown in forum Revit Architecture - General
    Last Post: 2005-02-05, 06:01 AM
