Please I need help with this roof, if anybody has a suggestion I will appreacite the help.
thanks
thanks
You are having fun here aren't you
I would draw them as seperate roofs & try joining them up (as far as Revit will allow me that is) Then I would cut & trim to fit
I also reckon you will need a valley on blue line location
Can anyone do this as a single roof ?
as a single roof in v7 - although bottom right roof not quite right...
Roger - wouldn't the blue line "valley" need to be at the roof junction?
Sorry Blads but I read the roof Far Left to be lower than the rest.
Is this Right or Wrong Wagurto?
Blue Line location I thought should be taken from the ridge & hip intersection ~ stand to be corrected
Doesn't look quite right with left most roof section floating above the main.
