I am running AutoCAD Map 3D 2011 on a 64-bit using Windows 7. We have 2008 SQL server and I am using ArcSDE to connect to the database. I checked to see if the ObjectID property was being Auto Generated and it is. I create a point by right clicking on the layer. When I try to check it in I get the following error message and it appears the ObjectID is not being Auto Generated. Is there some other variable that needs to be turned on?
Messages
Feature was not saved in the target feature source.
Message details
- Failed to insert feature
- 1=Failed to executed Fdo command.
- 2=Microsoft SQL Server Native Client 10.0: Invalid input parameters values. Check the status values for detail. (0)
- 3=Underlying DBMS error (-51)
- 4=Stream execute failed.
Failed to save edit set.
Failed to insert feature.
Failed to execute Fdo command.
Microsoft SQL Server Native Client 10.0: Invalid input parameter values. Check the status values for detail. (0).
~Sue
