Thread: File size
    2009-02
    83
    Default File size
    I'm working on a small office building...Its really small, but the file size is huge. Right now our file size is bigger that our 7 story super complex office building and we aren't even into CD's yet. I can't figure out why its so large.
    I've purged out all of the unused families but that decreased it from 109mb to 107mb. Not a big difference at all.
    Is there any way to see what the heck is causing such a big file?
    Certifiable AUGI Addict cliff collins's Avatar
    2003-09
    St. Louis, Missouri
    3,071
    Wink Re: File size
    1. Are there any imported Cad files? This often bloats file size. Get rid of all un needed cad files.
    2. In windows, look at the file size of the families which are loaded into the project and identify any abnormally large ones. Open them in Revit, Purge them, and reload into the project. We had a king size bed family inside a Group in a typical guestroom that was 12MB! Turns out it had 4 pillows nested into it, which were cad imports with thousands of polygons and that family was bloating the Revit file size. We cleaned it up, reloaded the family and the Revit file size went down substantially.
    3. When Synching to Central, make sure that only a single, simple view is open, and that no 3D views, esp. with shadows or realistic views are turned on. Make a simple "Closing Window" view and make all users have only that view open when Synch. to Central.
    4. See if any warnings are identified and try to resolve all of them. Of course Purge
    the project and perhaps Audit it when opening the Central file.
    cheers
    Cliff B. Collins, Registered Architect / BIM Specialist
    St. Louis, MO
    All AUGI, all the time Alex Page's Avatar
    2003-07
    Wellington, New Zealand
    793
    Default Re: File size
    Also , dont forget to try "Compress" when saving - try a save-as and its under "options"
    Alex Page
    RevitWorks Ltd
    Check out the Door Factory, a door maker add-in for Revit
  1. Allowable Forum file attachment types and their corresponding maximum file size
    By Mike.Perry in forum Forum Tips & Tricks (Read only)
    Last Post: 2007-05-28, 08:19 PM
  2. file size
    By thomasf in forum Revit Architecture - General
    Last Post: 2007-05-17, 12:17 PM
  3. Obtain best Image file size for placing in drawing file
    By cadmecheng in forum AutoCAD LT - General
    Last Post: 2006-06-02, 07:49 AM
  4. shape file / dbf file size
    By gis.68227 in forum AutoCAD Map 3D - Wish List
    Last Post: 2004-08-20, 01:35 PM
  5. File size
    By Gerhard in forum Revit Architecture - General
    Last Post: 2003-11-22, 01:21 PM
