Thread: Arial text bold in model space
    2003-01
    Denver, Colorado
    199
    Exclamation Arial text bold in model space
    I am having a problem with my labels in model space. They all look beautiful until I dview twist the view port then all the text looks and prints bold that is in model space... If I go into the view port and set the dview, points, to 0,0,0 and 0,0,1 it fixes it, BUT i cannot rotate the view port then. Any ideas what to do?
    2009-11
    5,719
    Default Re: Arial text bold in model space
    First rotate your UCS to the direction you want:
    (command "._ucs" "_z" pause)
    ... Then use the ._plan command to orient to 'Current UCS'.
    (command "._plan" "_current")
    Hope this helps!
    Computer Specs:
  1. Replies: 2
    Last Post: 2010-03-23, 07:22 PM
  2. Arial Bold and Arial Narrow Bold shx files
    By briand.87290 in forum AutoCAD Customization
    Last Post: 2008-03-13, 12:10 PM
  3. Dimension text with Arial Bold
    By Henry D in forum Revit Architecture - General
    Last Post: 2006-12-17, 08:27 PM
