Results 1 to 10 of 11
Thread: How to Constrain circle with another circle
    2005-09
    VARANASI in India
    290
    Default How to Constrain circle with another circle
    Is there any way to constrain a circle with another circle in touch ?
    LJU
    Revit BIM Consultant Alfredo Medina's Avatar
    2008-05
    Miami, FL
    998
    Default Re: How to Constrain circle with another circle
    One possible solution is this:
    See illustration. The user specifies values for the gap between the concentric circles and for the radius of the outer circle (R). The radius of the inner circle (r) is set to be = R - gap .
    2006-11
    159
    in touch? are they tangent?
    then set at their properties to show the centers and put a parameter (name it D) between the centers(tab to snap). Then control bouth radius with two parameters R1 and R2.
    In order to keep the tangent conditions you have a formula.
    if one circle is in the other one and R1>R2 then D=R1-R2
    if one circle is near the other one then D=R1+R2
    2008-05
    Miami, FL
    998
    Quote Originally Posted by gaby424 View Post
    Good question. The question needs a better description. I understood "in touch" as near, close, but you're right, it might also mean that the circles are touching at one point.
    2005-09
    VARANASI in India
    290
    Yes I have the same problem. If one circle touches at a point to other on it's circumference & need to constrain with that point. Here is an attached which is managed any how
    LJU
    2008-05
    Miami, FL
    998
    Quote Originally Posted by ljupadhyay View Post
    Yes I have the same problem. If one circle touches at a point to other on it's circumference & need to constrain with that point. ...
    LJU
    In your particular case, you need to determine how much, in proportion, the smaller circle enters into the bigger one. In this example the center of the small circle is separated by a distance equal to 3/4 of the length of the big radius.
    The illustration also shows other situations where a small circle is constrained to a bigger circle.
    2005-09
    VARANASI in India
    290
    It means center of a circle can be constrained to a ref. plane. But while constraing I never able to locate the center as it is normaly not visible
    LJU
    All AUGI, all the time Munkholm's Avatar
    2006-09
    The Kingdom of Denmark
    560
    LJU
    In that case, you just need to check "Center Mark Visible" at the Circles propertis dialog.
    And, having VG set to show "Automatic Dimensions" probably would´nt hurt either in this case.
    - Klaus Munkholm
    2005-09
    VARANASI in India
    290
    Thaks Munkholm
    Nice tip I never tried. Now the attache family is currected.
    LJU
    2004-06
    Memphis TN area
    6,719
    Whoa, I would not have figured something like that to need to be parametric. Are you planning on using this family in multiple locations with different sizes of the elements?
    AERC, PLLC
    Hernando, Mississippi
  1. CIRCLE - RAD,TAN,PT
    By marko_ribar in forum AutoLISP
    Last Post: 2011-10-01, 06:09 PM
  2. Dimension from face of circle to face of circle?
    By ljlange in forum Revit Architecture - General
    Last Post: 2009-10-18, 04:45 PM
  3. How to constrain Horzontal lines to circle
    By DoTheBIM in forum Revit Architecture - General
    Last Post: 2008-05-13, 07:01 PM
  4. Distance from circle to circle
    By Brian.164262 in forum AutoLISP
    Last Post: 2008-04-24, 05:31 PM
  5. Circle Polyline (ie Circle with Width)
    By johan d in forum AutoCAD General
    Last Post: 2006-02-03, 10:16 PM
