Thread: Exterior Material Composition
    2008-06
    61
    Default Exterior Material Composition
    Made a quick exterior rendering to show colors of materials for the client.
    2004-06
    Memphis TN area
    6,700
    Default Re: Exterior Material Composition
    Fairly monochrome, but still a nice composition. How did you do the metal roof's standing seams?
    AERC, PLLC
    Hernando, Mississippi
    2008-06
    61
    Quote Originally Posted by patricks View Post
    Made a small extruded roof based piece for the high part of the standing seam, than arrayed it across the area that was in view.
    We build mostly commercial, and 9 out of 10 we have standing seam roofs in our projects. I have never had luck with a rendering with a image trying to depict standing seam roofs, bump map stuff, just way faster to extrude a piece just for the rendering than let the .pat take care of the documents.
    All AUGI, all the time Max Lloyd's Avatar
    2004-07
    London, England
    782
    I have recently done that as a glazed roof. create mullions to represent the standing seams, and change the glass panels to something solid. A bit rough on the inside, but a quick and easy approach on the outside as you have so much control over how the seams are spaced out, and much easier as the roof goes around corners etc!
    Max
  1. Applying Material-Hatch Patches to Exterior
    By Mike_Maloney in forum Revit Architecture - General
    Last Post: 2008-08-20, 12:55 PM
  2. Exterior Wall Material
    By footbridge in forum Revit Architecture - General
    Last Post: 2007-08-09, 07:19 PM
  3. exterior wall material breaks off
    By boyd.112779 in forum Revit Architecture - General
    Last Post: 2007-04-20, 11:21 AM
  4. Material changes in exterior wall
    By Michelle Gibson in forum Revit Architecture - General
    Last Post: 2005-04-19, 08:37 PM
  5. Exterior Material Annotation & Schedule
    By barathd in forum Revit Architecture - General
    Last Post: 2004-08-16, 04:00 AM
