Thread: Creating rectangular Corridors
    2010-09
    Default Creating rectangular Corridors
    Hello all,
    I've encountered a bit of a problem. I have to build a corridor around a design that has squared off corners and when I go to build it, the corridor randomly tapers off when it reaches a corner. I've been told that corridors work beautifully when the corners are rounded but in my case it has to remain at ninety degrees. The alignment that I'm using is also, continuous and closed. Is there any way to have the corners join up better? I hope this is enough information to get a discussion started.
    Thanks in advance,
    Jaden
    2005-09
    Georgia
    82
    Default Re: Creating rectangular Corridors
    Any chance you could place a tiny arc at the bend? We do a lot of rivers and canals that have to remain within designated boundaries and it is how we work through that issue. The tiny arc also allows a section at that corner to work correctly too. The arc can be really tiny and doesn't really throw off the measurements of the alignment much.
  1. I would like to see support for creating custom curtain panels in non-rectangular cells
    Last Post: 2014-05-08, 12:48 PM
  2. Merging Corridors
    By DBill2508 in forum AutoCAD Civil 3D - Corridors
    Last Post: 2012-03-07, 10:25 AM
  3. Crossign Corridors
    By joaohc889949 in forum AutoCAD Civil 3D - Corridors
    Last Post: 2008-02-26, 04:04 PM
  4. Merge Corridors
    By wes.85389 in forum AutoCAD Civil 3D - General
    Last Post: 2006-02-23, 02:31 PM
  5. need a roadway-creating tool like corridors in civil3d
    By jiaoyanbing in forum Revit Architecture - Wish List
    Last Post: 2005-04-10, 06:56 PM
