We're having a little issue with blocks, and we're trying to narrow it down a bit - it's one of those annoying things that happens sometimes but not others, and we haven't figured out why, yet. I'm wondering if anyone else has seen this:
We have a number of standard annotation blocks - detail and section callouts, etc. They are annotative, and (typically) dynamic.
When placed in a model file they don't always show up in a sheet file when xreffed in.
It's not the obvious possibilities - not having the appropriate scale, or being on a frozen layer. Those things also happen from time to time, but they are easily fixed user errors. There is some other thing happening, which is what I'm working on.
If we purge the model file, and then reload the xref, that will fix it, at least for a while.
We have not determined (yet) if it's always annotative blocks, or always dynamic blocks, or always annotative dynamic blocks, although we're trying to determine if any of those conditions are required. Most of our projects are using the sheet set manager, so it could also be related to having placed the callout, or the view through SSM. Again, we're still trying to narrow it down.
So, has anyone seen something similar? If so, have you found a cause?.
