Thread: Electrical Project Database Info Goes Away
    2008-05
    4
    Default Electrical Project Database Info Goes Away
    I have an EPD setup in a view drawing, and I have that drawing xrefd in a sheet drawing. Everything looks fine and all info is there, but if I save and close then open the sheet again, all the panel and circuit info is gone and it's still referencing the EPD. So I have to detach, purge, then reattach the view dwg everytime I open the sheet. The view is showing correct information. Does anyone know why that information goes away?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,103
    Default Re: Electrical Project Database Info Goes Away
    Please note I have moved this thread from the AutoCAD 2011 General Forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Richard
    Forum Moderator
  1. Adding database info to objects in Map3d
    By kylejrausch in forum AutoCAD Map 3D - General
    Last Post: 2012-08-31, 04:14 PM
  2. electrical database problem
    By sean.127209 in forum AMEP General
    Last Post: 2012-06-19, 11:04 PM
  3. Electrical Project Database Problem
    By danielmoritz in forum AMEP General
    Last Post: 2009-08-07, 04:39 PM
