Thread: Corrupt File
    2008-11
    56
    Default Corrupt File
    I have have been doing a building model on university computers and then moved over to my computer located at home. After spending a considerable amount of time on it, I now find that when I transfer the file to any other computer, it comes up with an error upon opening...
    An error occured and the application will now close.Do you want to attempt to save a copy of the following scene.
    when i press ok, it comes up saying recovery failed. application will now close.
    Is there any way around this? thanks.
    ps. i have made a lot of saves, but the same problem occurs with all of them saved on the home computer. so going back is no option.
    All AUGI, all the time Elmo's Avatar
    2005-04
    South Africa
    959
    Default Re: Corrupt File
    Does it work fine on your home pc? If that is the case then you might need to consider that what you have done in the file could be really big and is crashing on any other machine. If that isn't the case then we will need to find out what other information we can to resolve the problem.
    I could stop if I wanted to loydg's Avatar
    2007-08
    Denver, CO
    323
    What about version compatability? Are you using the same version at both locations? That sounds like the error that I get when trying to open a file saved from a current version from an older version...
    Glen Loyd
    Parsons Brinckerhoff
    Lead Design Visualization Specialist
    3ds Max Design 2010 Certified Associate/Professional
    www.pbprojectviz.com
    www.pbviz.com/forum
    2008-11
    56
    They are both design 2010, it was done in a student edition but that should be the problem. The home computer is windows 7, and it opens in other windows 7's but not in any of the other operating systems that I have tried. I think I might just save a random file from windows 7 and see if it opens on the other systems, i guess if it does, then its my files problem. I will post the link to the file here if you have a chance to have a look at it, and tell me if it opens and what system you are running.
    http://dl.dropbox.com/u/12454306/theatre%20600.max
  1. Corrupt file... HELP!
    By Mikkelebrodersen in forum Revit Architecture - General
    Last Post: 2010-11-29, 10:05 PM
  2. Corrupt file
    By Chris DiSunno in forum Revit Architecture - General
    Last Post: 2009-04-07, 04:19 PM
  3. Corrupt File
    By dsw98 in forum Revit Architecture - General
    Last Post: 2008-06-09, 04:50 PM
  4. Help with corrupt file
    By warnoe uk in forum ACA General
    Last Post: 2007-04-20, 07:40 AM
  5. Corrupt File
    By Clyne Curtis in forum Revit Architecture - General
    Last Post: 2003-09-02, 03:32 PM
