Results 1 to 7 of 7
Thread: AutoTurn question
    2010-10
    Default AutoTurn question
    Hi all,
    does anyone know how to adjust the speed of the turning vehicle in Autoturn?
    2009-11
    5,719
    Default Re: AutoTurn question
    Edit:Congrats on your first post, and welcome to the forums!
    There are a couple of options for you to build your AutoTURN exhibit:
    • If you are using the 'Steer a Path' button, the mouse pointer movement controls the speed (to a point)
    • If you do not want to manually 'steer' through a turn, you can use the 'Generate Corner Path' button, and play with the constraints of the envelope (if there's a trailer, etc.)
    Hope this helps!
    Computer Specs:
    2003-10
    706
    In the 2006 version of Autoturn (all we have here) when you Generate Arc Path a small dialog box pops up that literally has a speed variable textbox to adjust the speed. We usually keep it at 1 MPH to generate the tightest path. I can't speak for the later versions of Autoturn
    100 Club andrewp's Avatar
    2003-06
    149
    CoolMo
    you might try to keep your speed up to 3 to 5 MPH if you are working with trucks entering and exiting your site. It will give you a more realistic idea of the vehicle needs to make it's turn. I use 5 MPH most of the time.
    drew
    2005-02
    2
    Quote Originally Posted by RenderMan View Post
    Hope this helps!
    I am having an issue trying to move an Autoturn created block to a different layer but can't change it. Any ideas?
    2009-11
    5,719
    Quote Originally Posted by archlemon View Post
    Not sure I understand the issue... The block, like any other, can be placed on any layer of your choosing (provided not currently on a locked layer). However, the AutoTURN blocks are comprised of geometry on AutoTURN specified layers (these may be modified in the AT settings).
    HTH
    Computer Specs:
    2003-06
    149
    First make sure that the target layer is not turned off, frozen or locked. The vehicle simulations can be placed on any layer. You can even specify which layer prior to placing the simulation. Under the property dialogue box of AutoTURN. (see attached image)
    drew
  1. 2015: AutoTurn Adaptive Simulation Question
    By laceyflash701780 in forum AutoCAD General
    Last Post: 2020-09-23, 12:45 PM
  2. Autoturn question
    By cadtag in forum Software
    Last Post: 2015-07-02, 12:21 PM
  3. Autoturn or Autotrack?
    By camilla.mott in forum AutoCAD General
    Last Post: 2008-05-07, 11:55 AM
  4. AutoTurn
    By thechinaman in forum AutoCAD General
    Last Post: 2007-09-06, 06:24 PM
  5. AutoTURN
    By dfarris75 in forum Civil 3D - Civil Design Companion - General
    Last Post: 2007-06-22, 01:05 PM
