Thread: Autocad 2010 keyboard shortcuts list
    2015-09
    146
    Default Autocad 2010 keyboard shortcuts list
    Can anyone tell me where i can find the Autocad 2010 keyboard shortcuts list from please ?
    2003-06
    Wollongong, Australia.
    47
    Default Re: Autocad 2010 keyboard shortcuts list
    acad.pgp file in your support folder
    C:\Program Files\AutoCAD Civil 3D 2010\UserDataCache\Support
    All AUGI, all the time Richard.Kent's Avatar
    2001-01
    Albuquerque, NM, USA
    622
    Quote Originally Posted by K.ATHERTON View Post
    Along with the aliases in the pgp file the following are set OOTB in AutoCAD.
    Switching between open drawings Ctrl + Tab
    Switching between open programs Alt + tab
    SHORTCUT KEYS
    *CANCEL* (Same as ESC)CTRL+ \
    Select All CTRL+A
    Snap toggle on/off CTRL+B
    Copy CTRL+C
    Toggle dynamic UCS CTRL+D
    Toggle Isoplanes CTRL+E
    Group Selection On/Off CTRL+H
    Toggle Coords CTRL+I
    Repeats last command CTRL+J
    Hyperlink... CTRL+K
    Toggle Ortho CTRL+L
    Repeats last command CTRL+M
    New... CTRL+N
    Open... CTRL+O
    Plot... CTRL+P
    Quits AutoCAD CTRL+Q
    Toggle viewports (PS) CTRL+R
    Save CTRL+S
    Toggles Tablet Mode CTRL+T
    Paste CTRL+V
    Cut CTRL+X
    Redo CTRL+Y
    Undo CTRL+Z
    Toggles Groups CTRL+SHIFT+A
    Copy with Base Point CTRL+SHIFT+C
    Toggles display of
    palettes with CTRL+SHIFT+H
    Quick Properties CTRL+SHIFT+P
    Save As... CTRL+SHIFT+S
    Paste as Block CTRL+SHIFT+V
    Moves to next layout tab
    to the left of current CTRL+PAGE UP
    to the RIGHT of current CTRL+PAGE DOWN
    Clean Screen CTRL+0
    Properties CTRL+1
    DesignCenter CTRL+2
    Tool Palettes Window CTRL+3
    Sheet Set Manager CTRL+4
    Info Palette CTRL+5
    DBCONNECT CTRL+6
    Markup Set Manager CTRL+7
    QuickCalc CTRL+8
    Command Line CTRL+9
    Help CTRL+F1
    close drawing or app CTRL+F4
    Help F1
    Open Text window F2
    Toggles Object Snap Mode F3
    Toggle Isoplane F5
    Move between open drawings F6
    Grid on/off F7
    Toggles Orthogonal Mode F8
    Toggles Snap Mode F9
    Toggles Polar Mode F10
    Toggles Object Snap Track Mode F11
    Suppress Dynamic Input F12
    Macros Alt+F8
    Visual Basic Editor Alt+F11
    TEMPORARY OVERRIDE KEYS
    help files lists two overrides for some commands,
    try both to see which one(s) work for your setup
    Toggles Orthogonal Mode SHIFT
    Toggle Object Snap Mode SHIFT+A
    Toggles Object Snap Mode SHIFT+'
    Object Snap Override : Center SHIFT+C
    Object Snap Override : Center SHIFT+,
    Disable All Snapping and Tracking SHIFT+D
    Object Snap Override : Endpoint SHIFT+E
    Object Snap Override : Endpoint SHIFT+P
    Disable All Snapping and Track SHIFT+L
    Object Snap Override : Midpoint SHIFT+M
    Object Snap Override : Midpoint SHIFT+V
    Toggle Object Snap Tracking SHIFT+Q
    Toggle Object Snap Tracking SHIFT+]
    Enables Object Snap Enforcement SHIFT+S
    Enables Object Snap Enforcement SHIFT+;
    Toggle Polar Tracking SHIFT+X
    Toggle Polar Tracking SHIFT+.
    Toggle UCSDETECT SHIFT+Z
    Toggle UCSDETECT SHIFT+/
    2000-01
    Seattle WA USA
    5,859
    Exclamation Re: Autocad 2010 keyboard shortcuts list
    Quote Originally Posted by Thundercleese View Post
    That's not the correct folder for a user. The correct folder would be:
    %AppData%\Autodesk\AutoCAD 2010\R18.0\enu\Support
    Note the folders in red will varying depending on version and language.
    R. Robert Bell
    Design Technology Manager
    Stantec
    2009-08
    93
    you can enter this at command line
    _ai_editcustfile acad.pgp
    2011 has a Edit Aliases button on the manage tab
    But for ShortCut Keys
    Enter at the command line
    Cui
    And Select the ShortCut Keys
    See the pic
    This info is from Sinc a Augi member
    at this link http://www.theswamp.org/index.php?topic=35047.0
  1. List of Keyboard Shortcuts ??
    By thand in forum Revit Architecture - General
    Last Post: 2010-04-16, 02:54 AM
  2. 2010 - Keyboard Shortcuts
    By saeborne in forum Revit Architecture - General
    Last Post: 2009-05-21, 06:16 PM
  3. Additional Keyboard Shortcuts - 2010
    By need4mospd in forum Revit Architecture - General
    Last Post: 2009-05-13, 04:41 PM
  4. Keyboard Shortcuts 2010
    By iankids in forum Revit Architecture - General
    Last Post: 2009-04-24, 07:05 AM
