hi all
can any one tell me how to run SDK samples
i am using revit 2011 and have install vs 2008. I am just new to this and
I have been studing about Revit 2011 api's i have just running some sample
applications and but i am not able to run the sdk sample programs like
AllViews
I have added the the references and edited the revit.ini to the AllViews class
and give the path C:\Program Files\Autodesk\Revit Structure 2011\Program\Revit.exe
and when i run it its not showing in the adding
i am new to this the reason why i am doing this is i need to know how to put a sheet
Currently Revit does not place views of plans on sheets automatically. Therefore this is a manual process and therefore difficult for the drafter to place the view in the exact place from sheet to sheet so that the grids are in the same location from sheet to sheet. A tool would need to be created so that all views that are assigned to a specific scope box be placed on sheets at the same location. This would insure that plans are at the same location on a sheet from level to level.
if any one have any suggestion please feel free to comment on it
Thanks
