Thread: UTM aerial into State Plane drawing
    2005-07
    Default UTM aerial into State Plane drawing
    Hi,
    Using Map only. I need to insert an aerial image (.tif with.tfw) that is UTM NAD83 Zone13 Meters, or UTM83-13 into my basemap drawing which is NAD83 HARN, State Plane Colorado, North Zone, US Survey Feet, or COHP-NF.
    I've tried several ways and can't make it work. Any help would be appreciated. Thanks,
    macdonim
    2001-05
    Austin, TX USA
    2,201
    Default Re: UTM aerial into State Plane drawing
    There are two ways. First you'll need to assign the coord system to your drawing if you haven't already.
    First and simplest way is using FDO. This will automatically transform the image to the correct system. There are some limitation, especially if your're sharing with non-map users.
    Second way is to create a new drawing and set its coord system to be the same as the image. Import the image and save/close drawing. In your basemap, query in the new drawing containing the image. The query will transform to your basemap coord system.
  1. 2011: Plant grid coordinates vs world/state plane
    By cadtag in forum AutoCAD General
    Last Post: 2013-02-15, 07:49 PM
  2. Transfer to State Plane
    By maccad3d472740 in forum AutoCAD Civil 3D - General
    Last Post: 2011-09-20, 11:07 PM
  3. Convert State Plane to UTM
    By mkredhage in forum AutoCAD Civil 3D - General
    Last Post: 2010-09-14, 12:54 PM
  4. state plane coordinates
    By tom.starkweather in forum AutoCAD Civil 3D - General
    Last Post: 2009-04-15, 04:51 PM
  5. Transforming a DWG from NAD27 to NAD83 in the state plane environment
    By beachmystic in forum AutoCAD LT - General
    Last Post: 2007-12-05, 02:30 AM
