Results 1 to 10 of 12
Thread: Laptop Specs for revit 2011 architectal suite?
    2008-08
    Auckland New Zealand
    52
    Default Laptop Specs for revit 2011 architectal suite?
    A friend is looking for a budget (student) laptop for revit wat would u suggest?
    2006-06
    Smile Re: Laptop Specs for revit 2011 architectal suite?
    Quote Originally Posted by speedfreak5150 View Post
    any brand that has 8GB RAM and a VideoCard that can handle pixel shader3!
    I could stop if I wanted to Dave Jones's Avatar
    2005-12
    San Luis Obispo, CA
    285
    Default Re: Laptop Specs for revit 2011 architectal suite?
    that's like asking "what kind of car do I buy to drive to the grocery store?". Any car will get you there, some more smoothly and more quickly than others. I run Revit 2011 occasionally (when I travel) on a Dell Precision M6300 with 2GM RAM. It's acceptable and that's about as far as I go.
    Dave Jones
    Drafting & Design Plus (DDP)
    OneBox 2014 Win 7 Pro 64 bit
    Intel I7-3770k @4.44mhz
    32GB DDR3 RAM GeForce GTX670
    100 Club vgonzales's Avatar
    2006-01
    New Haven, CT
    134
    Windows 7 Pro 64-bit
    8 GB RAM
    300 GB HD
    512 MB video card (must support DirectX 10)
    Currently, my company buys HP ProBook series of notebooks for $1400 (with the extra RAM installed) from CDW with 3 year accidental damage protection coverage.
    Regards,
    Leo
    Virgilio Gonzales, AIA
    "Stop drawing! Start Building!"
    HP ProBook 4730s, Win 7 Pro x64 SP1, Intel Core i7-2630QM 2.00 Ghz, 8 GB RAM, Revit Arch 2012 WU-2 & 2013 WU-2
    2010-03
    36
    check this thread and other threads in this section:
    http://forums.augi.com/showthread.php?t=70738
    i recently purchased a refurbished dell inspiron with a 25% off coupon and it's doing me fine for the work i do at home after work. The file sizes I'm working with at home, however, are usually no larger than 30MB; if your friend already has projects s/he's done in Revit, s/he should check the file sizes of those projects as that will be a good indicator of how powerful of a laptop will be necessary. I didn't want to spend a lot on a computer and have to try to stretch it out for 4+ years so I spent less and got something that (so far it seems) is moderately more than enough.
    specs on my laptop (dell inspiron):
    17"
    win7 64
    processor: i5 450m
    ram: 4gb
    hd: 500gb @ 4500 rpm
    vid card: 512mb
    Since your friend is a student, the pro version of win7 shouldn't be necessary but definitely get the 64-bit version.
    When I was searching out laptops, my ideal was:
    win7 64
    i7 processor
    6gb ram
    7200 rpm hard drive
    512mb-1gb ram vid card
    Specs like that will easily run you over $1000, however. Mine was $550.
    If your friend is getting a laptop (or desktop for that matter), I definitely recommend budgeting for a 2nd monitor as well. Working on a laptop alone is fine when you need to, but if you're at studio for hours on end, you might as well invest another $150 for a 24" monitor.
    Quote Originally Posted by Dave Jones DDP View Post
    Dave has a good point here...a "budget" laptop isn't gonna Run Revit that well, most likely. All that said, if you want to do a little more research, I made a few posts here that help describe what things you should get in your computer.
    2008-08
    52
    another question if getting a i7 processor how many Ghz do you need?
    Pittsburgh, PA USA
    1,906
    This is again, a slightly obscure question. The easy answer is as fast as possible!
    To be more pragmatic, how large are the files going to be? 100 meg or so (without a lot of warnings) 2.93 gHz will do nay larger and 3.33 or 4 will be needed. Yes, buying the laptop for "today" allows you to get away for less, but looking at the requirement jumps of the last two releases of Revit, you've got to buy for at least 2 years ahead on "now" to make the purchase worth it.
    2005-12
    566
    I bought a Dell Studio XPS (which is hard to find on their web site), but it's like butter. Windows7-64, 8 gigs of RAM, i7 1.60 GHz processor. Only thing is it's very crashy, and I haven't figured out why.
    2006-12
    Big "D"
    3,709
    Quote Originally Posted by Scott Womack View Post
    I'm running a Dell M6500 Covet with i7 820 1.73Ghz chip and it flies. I don't think the i7 chips are rated the same as the Core2 chips are. My device manager is showing 8 processors! lol
    Full Specs are:
    Dell M6500 Covet
    i7 / 820 1.73Ghz
    8G DDR 1066 RAM
    Nvidia Quadro FX 3800M 1G video card
    300G 7200 RPM hard drive
    Edge to Edge display.
    It's pretty sweet. I love it.
    Why is it called common sense when it is so rare?
    RevitForum.org
  1. Visualization Suite 2011 downgrade in 2012? (no Navisworks)
    By autodesk.224444 in forum Revit Architecture - General
    Last Post: 2011-06-11, 06:09 AM
  2. specs for a new laptop
    By Maverick91 in forum Hardware
    Last Post: 2010-09-10, 08:13 PM
  3. Is AutoCAD 2011 included with Revit Structure Suite 2011
    By durentech in forum Revit Structure - General
    Last Post: 2010-06-24, 01:27 AM
  4. Revit Architechure 2011 Specs
    By speedfreak5150 in forum Revit Architecture - General
    Last Post: 2010-05-24, 07:37 PM
  5. Where is AutoCAD 2011 in the AutoCAD Revit Structure Suite 2011 bundle?
    By Dariusz.Kwolek in forum AutoCAD Structural Detailing
    Last Post: 2010-04-26, 09:42 AM
