Thread: Schedule, detail lines.
    2008-03
    29
    Default Schedule, detail lines.
    Can you schedule detail lines?! If so, how?
    AUGI Addict jeffh's Avatar
    2002-09
    Manchester, NH
    1,087
    Default Re: Schedule, detail lines.
    No this is not possible. Detail lines are view specific. Only model objects can be scheduled.
    2004-06
    77
    I'd be curious to know the reason behind this? We often look for info about Detail Lines and can export them to Excel, as a quality-control issue, but off-hand I can't think why this would be scheduled?
    2008-03
    29
    That's what I feared.
    I need to measure grooves that are to be made in a slab-structure under walls between different functions in the building. The grooves are there to stop sound from travelling to and from certain rooms through the slab. Not all the rooms needs this, or else I could make a wall schedule. Some places the grooves are'nt the full lenght of the walls drawn. If I were to make a wall-schedule, I would have to split the walls where the grooves stop, which means lot's of work. There are also curtain walls.
    I tried selecting all the detail lines, but it didnt give me a combined length.
    Any pointers?
    2006-01
    4,516
    Use a line based Generic model, that just has a symbolic line in it, and a Shared parameter for length. Then its "modeled," exists in 3d space, is something real, and can be scheduled and seen in every view.
  1. 2013: Schedule a detail lines
    By forum_ing in forum Revit Architecture - General
    Last Post: 2013-01-28, 07:24 PM
  2. Detail cut lines - how can I make my detail cut family scale automatically?
    By Margarita in forum Revit Architecture - General
    Last Post: 2009-09-11, 06:48 AM
  3. Ability to convert detail lines to model lines and vice versa
    Last Post: 2008-03-10, 10:11 AM
  4. Changing Model lines to detail or symbolic lines
    By Jason in forum Revit Architecture - General
    Last Post: 2005-05-21, 10:36 PM
  5. Detail boxes OR Can I draw detail lines outside a crop...
    By dredhead1832 in forum Revit Architecture - General
    Last Post: 2003-12-18, 07:22 PM
