Results 1 to 7 of 7
Thread: ECCENTRIC REDUCER?!?!?
    2010-10
    6
    0 Did you find this post helpful? Yes
    Default ECCENTRIC REDUCER?!?!?
    i'm trying to make an eccentric reducer and i'm about to throw my computer out the window!
    i've read other forums and it says just align the edges of two ducts, so i did that and it comes up with the picture you see at the bottom. the thing is, if i do the same thing in a different file, it works! what's going on!?!?!?
    2004-06
    Port Moody, BC
    346
    Default Re: ECCENTRIC REDUCER?!?!?
    Have you tried the Justify tool?
    Select the 3 items, both ducts and the transition, and on the ribbon you should see the tool, you can then select 1 of 9 justification points for the transition.
    2010-10
    6
    yeah, i tried it... it says "no auto route solution was found"
    it's weird because i can do it fine when i open a different project. i don't get why it won't do it on this one
    2003-06
    Manchester, NH
    222
    What is the transition family that is being used? Is it the one that ships with the provided templates or is it something that has been "customized"? If the transition isn't built to support justification the application won't be able to correctly justify the items.
    jason
    The Silent Type tuitvlugt's Avatar
    2015-09
    Edmonton, AB, Canada
    29
    1 Did you find this post helpful? Yes
    Your issue could stem from drawing ductwork at a particular height offset. This offset measures to the center of the duct. When you hit your transition with an eccentric top the center offset of the new duct is shifted vertical but the end of the next piece of ductwork is back at the original offset. This would make it appear that your transition is also part elbow, bending your ductwork verticaly.
    The trick is to construct your offset with a yes/no parameter for eccentricity. Make the default no (ie concentric) and draw the ductwork. Afterward, go back, select the transition, and check the eccentric box. Revit will then automaticaly adjust the offset off the connected ductwork.
    Trevor M. Uitvlugt P.Eng, LEED® AP
    BIM Manager
    Hemisphere Engineering Inc., Edmonton AB
    tuitvlugt@hemisphere-eng.com
    "If you don't like change, you're going to like irrelevance even less." - General Eric Shinseki, Chief of Staff, U.S. Army
    Certifiable AUGI Addict cliff collins's Avatar
    2004-05
    St. Louis, Missouri
    3,135
    Red face Re: ECCENTRIC REDUCER?!?!?
    Could not resist---
    Isn't a "eccentric reducer" a weird flaky boss, who lays off all his best workers?
    cheers.................. from the "archy" side
    Cliff B. Collins, Registered Architect / BIM Specialist
    St. Louis, MO
    2012-03
    So any quick and efficient step to create an 800 mm Eccentric Reducer. Thanks.
  1. 2012: PIPE REDUCER IS NOT WORKING
    By amityaashu in forum Revit MEP - General
    Last Post: 2012-04-25, 12:32 PM
  2. Reducer Eccentric
    By longnhietlanh996328 in forum Revit MEP - General
    Last Post: 2011-04-01, 04:24 PM
  3. Eccentric Reducer
    By BeKirra in forum AutoCAD 3D (2007 and above)
    Last Post: 2009-05-04, 08:40 AM
  4. Eccrntric Reducer
    By BeKirra in forum Inventor - General
    Last Post: 2008-12-15, 01:11 AM
  5. 3D Solid eccentric reducer
    By richard.ash.106509 in forum AutoCAD 3D (2006 or below)
    Last Post: 2006-07-27, 12:02 AM
