Thread: RAC 2011 - pdf file size smaller as presentation
    AUGI Addict ws's Avatar
    Ambleside, Lake District, UK
    1,222
    Default RAC 2011 - pdf file size smaller as presentation
    I always assumed that using the 'Presentation' option in the print dialog would produce a better but larger file plotted to pdf...
    Just comparing an A1 drawing plotted out of RAC 2011 to pdf - 'High' option gives 2.2 MB whereas 'Presentation' gives 1.3MB file size.
    Strange - comparing the pdfs the 'High' output version does seem sharper than the 'Presentation' output - perhaps more anti-aliasing in the Presentation version?
    2007-04
    Ottawa, ON
    91
    Default Re: RAC 2011 - pdf file size smaller as presentation
    Just tried it here. Using 'High' produces a MUCH sharper output than 'Presentation'. Especially when using shadows on Elevations. Now I can finally use shadows without it looking like garbage. Never thought to try 'High' output
    As for the file sizes, I'm not too concerned about it but High output was smaller in size for my test.
    2006-01
    New Haven, CT
    136
    Quote Originally Posted by harrisbrett View Post
    Is "High" the default in the when starting a new project?
    I think it is.
    Thanks for the heads up. Glad to know that Presentation does not do better PDFs than the default High setting.
    2009-03
    105
    Quote Originally Posted by ws View Post
    i just tried both options and it looks to me like you are correct.
    maybe filesize has got more to do with your pdf printer. have you ever seen how massive a pdf produced in photoshop is (compared to acrobat)?
    1,222
    Quote Originally Posted by tropitech View Post
    But Photoshop pdfs will likely contain mostly bitmap information and so would likely be larger than Revit output?
    I notice that Acrobat 9 pdf output by default is 1200 dpi which I always change to 600 dpi with the Revit raster output set to high, a combination that seems to give good results but reasonable file size for emailing.
  1. 2014: Smaller program file size? HAH yeah right!
    Last Post: 2013-04-29, 09:11 PM
  2. Smaller model text size?
    By seventwo in forum Revit MEP - Families
    Last Post: 2007-06-01, 06:28 PM
  3. How to make PDF output file size smaller
    By lambertm in forum AutoCAD Plotting
    Last Post: 2006-06-06, 01:04 PM
  4. How to keep REVIT file size smaller
    By Chirag Mistry in forum Revit Architecture - General
    Last Post: 2005-07-28, 05:45 PM
