Results 1 to 9 of 9
Thread: sequence redefine leadership and direction of a polyline composed of lines and arcs
    2009-01
    33
    Default sequence redefine leadership and direction of a polyline composed of lines and arcs
    you can redefine the squenza points, and their line of a polyline?
    In practice I have many polylines which I want to change the start and then the sequence of the other, or the direction.
    basically I want to export the heads and try to pass the txt file to a CNC machine.
    thanks
    2000-01
    Seattle WA USA
    5,859
    Default Re: sequence redefine leadership and direction of a polyline composed of lines and arcs
    In AutoCAD 2011 the PEdit command has an option to reverse the PLine.
    R. Robert Bell
    Design Technology Manager
    Stantec
    2008-02
    1,141
    Quote Originally Posted by RobertB View Post
    Wow, is that what he meant?
    2009-01
    33
    I want to change the initial vertex and direction of a polyline made up of lines and arcs.....
    I hope I was clear
    thank you
    2015-10
    Belgrade, Serbia, Europe
    564
    If you change initial vertex of a polyline, the whole polyline would look different... In CAD it is essential important the order of procedure of witch the entities are created... This order is kept in its memory and entity data... You can only modify entity in new manner, but everything previously made will be the same... Just think of it, you have polyline; and if your first vertex becomes someone else, entity data would be moved from initial first (assoc 10 edata of a polyline) to some else (assoc 10 edata) and what would be with other (assoc 10 edata) ? - one part of the list of entity data would remain the same - from that some (assoc 10 edata) to the end, but first part - to that some (assoc 10 edata) would go to the end... The whole look of polyline would be different...
    Direction of entity you can change in ACAD 2011 by reversing order of points through PEDIT -> edit vertex -> reverse ... Then the polyline would look the same and only procedure of its creation would be inverted...
    2015-10
    564
    Anyway, if the polyline is closed - for other I don't guarantee that you'll get result you want, you can apply this routine :
    (defun c:ChInitVert ()
    (prompt "\nPick closed polyline with arcs")
    (setq e (car (entsel)))
    (setq ed (entget e))
    (setq edd nil)
    (setq q -1)
    (while (< q 0)
    (progn
    (setq ec (car ed))
    (setq ed (cdr ed))
    (if (eq (car ec) 10) (progn (setq ed (cons ec ed)) (setq edd (reverse edd)) (setq q 1)) (setq edd (cons ec edd)))
    (setq eddd nil)
    (setq eddd1 nil)
    (setq eddd2 nil)
    (setq eddd ed)
    (setq m (getreal "\nInput number of witch vertex do you want to become initial counting original as 0 : "))
    (setq n (* m 5))
    (setq i 0)
    (foreach ec eddd
    (progn
    (setq i (+ i 1))
    (if (<= i n)
    (setq eddd1 (cons ec eddd1))
    (if (> i n)
    (setq eddd2 (cons ec eddd2))
    (setq eddd1 (reverse eddd1))
    (setq eddd2 (cdr eddd2))
    (setq eddd2 (reverse eddd2))
    (setq eddd3 '((210 0.0 0.0 1.0)))
    (setq newed (append edd eddd2 eddd1 eddd3))
    (entmod newed)
    (entupd e)
    (princ "\nAfter ChInitVert, run PEDIT->Edit Vertex to see change")
    (textscr)
    (princ)
    M.R.
    Last edited by marko_ribar; 2010-10-20 at 02:09 PM. Reason: CODE IS NOW GOOD - TEST IT
    2009-01
    33
    it's not good routine for pline with many arcs........because change the look of the polyline
    2015-10
    564
    I've made corrections...
    test it now...
    M.R.
    To see another solution view :
    https://forums.augi.com/showthread.php?p=1105551
    Last edited by marko_ribar; 2010-10-21 at 08:14 AM. Reason: more elegant solution of routine...
    2008-02
    1,141
    I wrote this for reversing the direction of LWPolylines, Lines and Splines.
  1. Spline algorith for polyline arcs
    By Alex.Kostikov in forum AutoCAD General
    Last Post: 2010-01-20, 10:00 PM
  2. Replies: 6
    Last Post: 2009-04-16, 11:23 AM
  3. Family Composed of Symbolic Lines Only
    By jeff.richards in forum Revit Architecture - Families
    Last Post: 2008-12-07, 09:13 PM
  4. Help reversing direction of polyline
    By jpaulsen in forum AutoLISP
    Last Post: 2006-12-20, 02:26 PM
  5. Linetype text direction on arcs
    By Ammon in forum AutoCAD Customization
    Last Post: 2005-12-08, 04:42 PM
