Results 1 to 6 of 6
Thread: autocad 2006 -- commands not working
    2007-01
    4
    Default autocad 2006 -- commands not working
    i am having difficulty in one file drawing. my offset, line, mirror etc will not work. while copy and move commands do work.
    i must have accidentally modified something in this dwg but can't seem to figure out what it is... any suggestions?
    thanks.
    2009-11
    5,719
    Default Re: autocad 2006 -- commands not working
    Hello again!
    If you keyboard shortcuts, aren't working, perhaps testing these will let us know if there is a problem with the commands themselves, or just your keyboard shortcuts... for example, instead of typing OF for "Offset", try using in the ._offset command.
    If the latter works, and the former does not, then perhaps some tweaking of your .PGP file is in order.
    If the latter does not work, then perhaps the command has been undefined. This can be corrected by using the ._redefine command, then enter the command name.
    Hope this helps!
    Computer Specs:
    2007-01
    4
    both are not wroking. but only in this one dwg
    2007-01
    4
    i think i just found the issue... i noticed while picking points i am being told i am "ouside limits"
    2007-01
    4
    thank you for you help renderman!! i turned off my limits and i'm all set....
    studpid problem.... ggggggrrrrrr
    2009-11
    5,719
    Quote Originally Posted by brenda.132460 View Post
    You're welcome.
    If it weren't for those... I tell ya.
    Computer Specs:
  1. AutoCAD 2008 Hydracad commands not working in enterprise CUI
    By Jim Thompson in forum AutoCAD CUI Menus
    Last Post: 2007-07-12, 09:10 PM
  2. Time delay when using certain commands in AutoCAD LT 2006
    By nw-surv3 in forum AutoCAD LT - General
    Last Post: 2007-02-14, 12:02 PM
  3. Replies: 3
    Last Post: 2006-08-10, 06:00 PM
  4. AutoCAD LT 2006 - Layfrz and Xlist commands
    By cruzdc in forum AutoCAD LT - General
    Last Post: 2006-05-30, 08:35 AM
  5. Commands not working in AutoCAD 2002
    By gqube in forum AutoCAD General
    Last Post: 2005-10-08, 08:51 PM
