Best Practice for Grade Beams
The threads I have found seem rather old and I'm certain revit has evolved since.
I'm trying to figure out the best practice method of embedding grade beams within my slabs.
- I would like to model my slab as designed (200, 350 or 600 etc.)
- I would like to model my grade beams as designed (300x600, 750x1000 etc).
- I would like my model material volumes accurate as we intend to scale up to eventually do material take-offs.
If I use concrete beams, then the beams and Floor (slab) automatically join themselves in 3D.
This is a good sign I think.
Unfortunately, it becomes a light solid line in Plan View.
If I use Foundation Slabs or Walls, then they will intersect (and take precedence) with the Floor (slab) in 3D.
Both methods seem to require me to use the join tool to fix linework when taking sections.
If I use Foundation Slabs and join it to my Floor Slab, the Foundation slab will take precedence in 3D.
It becomes a hidden line in Plan View (this is good).
If I use Walls and join it to my Floor slab, Floor Slab will take precedence in 3D.
The wall will dissapear in plan view.
Ideally, I think I'd like Beams to work.
- When embedded, have them automatically show up as hidden in Plan View
Your opinions would be greatly appreciated.
cheers,
