Thread: AutoCAD Warning
    Member ed.kinsel's Avatar
    2004-12
    2
    Default AutoCAD Warning
    Greetings-
    Most of the time when I try to plot, I get the following warning:
    "SERVER1HP Laser Jet 8100 Series PCL 6: The plotter cannot be used for one of these reasons: the driver cannot be found, the device cannot be found, or the driver has a problem. The none plot device has been substituted." Recently, our server crashed and this has been happening to everyone. When the following is chosen "SERVER1HP Laser Jet 8100 Series" in the plot dialog box, it works fine. I can then save the file and it will plot beautifully. Is there any way to substitute the working one for the non-working one?
    Thanks!!
    2015-12
    Arizona
    2,478
    Default Re: AutoCAD Warning
    Why not install or rename the plotter as it WAS so that the name matches?
    2004-12
    2
    Quote Originally Posted by mjfarrell
    Thanks-I'll talk to the IT guy.
  1. 2012: AutoCAD Warning at Startup
    By heinsite in forum AutoCAD General
    Last Post: 2012-12-26, 08:01 PM
  2. Autocad Map Warning
    By Hammer.John.J in forum Geospatial - General
    Last Post: 2009-08-25, 09:14 PM
  3. Warning Routine Before AutoCAD Loads
    By Kevin Janik in forum CAD Management - General
    Last Post: 2007-08-04, 06:17 AM
  4. AutoCad Exits with no warning
    By ccowgill in forum AutoCAD General
    Last Post: 2005-08-16, 10:56 AM
  5. AutoCAD Warning message
    By jasontirone in forum ACA General
    Last Post: 2005-06-24, 04:45 PM
