Thread: Parameter Elevation Problems
    2010-10
    3
    Question Parameter Elevation Problems
    Ok I have been trying to figure out how to tag the top elevation of a footing, column, or framing. I have an elevation tag for footings but it reads from the bottom of footing and can't for the life of me figure out how to change that to top. I know in the parameters of the footing it has a Elevation at Dottom Parameter which I need to change to Elevation at Top. I need to create one of these also for the columns and the framing. If anyone would know how to do this would you please let me know. Thank you.
    2008-04
    269
    Default Re: Parameter Elevation Problems
    Are you using the default elevation tag? (System family)
    You can set the selection in the instance properties. (Refer to the attached image)
    You can either select the top of the element, the bottom, or the top and bottom. The final option is the part of the element you have selected.
    The symbol can be changed to suit your requirements.
    Does that help?
    Regards
    Regards
    Glenn
    Check out my blog - http://revitst.blogspot.com/
  1. Elevation View Parameter
    By rudolfweyers346383 in forum Revit Architecture - General
    Last Post: 2010-03-29, 10:52 AM
  2. Parameter Problems
    By dimitri in forum Revit Architecture - Families
    Last Post: 2009-04-09, 02:25 PM
  3. Elevation parameter in some families
    By overcaffeined in forum Revit Architecture - General
    Last Post: 2003-08-14, 07:26 AM
