Is there a way to choose wich wall 'turns' at a corner?
Try the Wall Joins tool - found in Modify > Geometry. Activate the tool, then click on the corner you want to edit, and then look at the Option bar, and choose Next, or Squared, or Mitre, to make it suit your needs.
I've done that.
It works if the walls are squared if you have changed the profile in one of the walls it doesn't. (not all the time)
But that was not my question.
My question is: can yo pick which wall to go around (the corner) or revit picks it automatically
Can you post an image of what you are trying to achieve?
Do you want a wall to 'follow the corner' and once it has gone through the corner, join to a different type of wall?
Not sure if this is will help your particular case but try selecting the wall & right clicking on the wall end 'dot'.. select 'diallow join'
note: You may have to do this for both the walls at the corner
Use the extend command or similar to manipulate wall end
This may give you more control over which wall extends etc
... this could be a handy option for framing members in some situations
I am having trouble accessing the wall joins function. When I go to Modify-->Geometry-->Wall Joins and then I select the grayed box over the corner of the walls I'm trying to join, the options bar has the display pull down grayed out and won't let me select anything. Has this happened to anyone else and how do I go about making the wall join function work again?
Thanks!
