Thread: Dbconnect in Windows 7
    2001-01
    169
    Unhappy Dbconnect in Windows 7
    Hi All-
    Has anyone been able to get dbconnect to work on a Windows 7 64 bit station with AutoCAD 2011 64bit? We are trying to connect to an access 2007 database and we continue to get an error. I have done some research and I found that some sites that say until MS Office 2010 is officially out the problem will continue to exist. I have tried downloading an ODBC driver for Windows 7 64 bit and that didn't seem to correct the problem either. Any and all suggestions are welcomed. Thanks.
    Manuel A. Ayala
    2001-12
    20
    Default Re: Dbconnect in Windows 7
    Hi,
    There is no 32-bit driver for Access, so this problem happens. Not sure which language you used to program this application, but you must compile it as a 32-bit application.
    Cairo - no, not Illinois
    2,786
    Might want to look into converting the access db to the SQLServer Express.... MS doesn't seem to want to keep the old DB tech working anymore
    Officially Awesome
    http://ascelibrary.org/doi/book/10.1061/9780784412077
    2004-05
    12
    Moderator BlackBox's Avatar
    2009-11
    2,499
    You *should* still be able to access the database via ActiveX:
    _$ (vl-load-com)
    _$ (setq ac (vlax-get-or-create-object "Access.Application"))
    #<VLA-OBJECT _Application 2ba96fbc>
    _$
    _$ (vlax-dump-object ac T)
    ; _Application: nil
    ; Property values:
    ;   AnswerWizard (RO) = Exception occurred
    ;   Application (RO) = #<VLA-OBJECT _Application 2ba96fbc>
    ;   Assistance (RO) = #<VLA-OBJECT IAssistance 2ba9716c>
    ;   Assistant (RO) = #<VLA-OBJECT Assistant 2ba971fc>
    ;   AutoCorrect (RO) = #<VLA-OBJECT _AutoCorrect 2ba9728c>
    ;   AutomationSecurity = 2
    ;   BrokenReference (RO) = You made an illegal function call.
    ;   Build (RO) = 6535
    ;   CodeContextObject (RO) = There is no current code context object.
    ;   CodeData (RO) = #<VLA-OBJECT _CurrentData 2ba9731c>
    ;   CodeProject (RO) = #<VLA-OBJECT _CurrentProject 2b648a5c>
    ;   COMAddIns (RO) = #<VLA-OBJECT COMAddIns 2b649674>
    ;   CommandBars (RO) = #<VLA-OBJECT _CommandBars 2b649794>
    ;   CurrentData (RO) = #<VLA-OBJECT _CurrentData 2b648d74>
    ;   CurrentObjectName (RO) = ""
    ;   CurrentObjectType (RO) = -1
    ;   CurrentProject (RO) = #<VLA-OBJECT _CurrentProject 2b649554>
    ;   DBEngine (RO) = #<VLA-OBJECT _DBEngine 2b6493a4>
    ;   DoCmd (RO) = #<VLA-OBJECT DoCmd 2b64923c>
    ;   FeatureInstall = 0
    ;   FileDialog (RO) = ...Indexed contents not shown...
    ;   Forms (RO) = #<VLA-OBJECT Forms 2b6492cc>
    ;   IsCompiled (RO) = You made an illegal function call.
    ;   LanguageSettings (RO) = #<VLA-OBJECT LanguageSettings 2b64935c>
    ;   MacroError (RO) = #<VLA-OBJECT _MacroError 2b64959c>
    ;   MenuBar = ""
    ;   Modules (RO) = #<VLA-OBJECT Modules 2b6496bc>
    ;   Name (RO) = "Microsoft Access"
    ;   NewFileTaskPane (RO) = #<VLA-OBJECT NewFile 2b648f24>
    ;   Parent (RO) = #<VLA-OBJECT _Application 2ba96fbc>
    ;   Printer = #<VLA-OBJECT _Printer 2b648ce4>
    ;   Printer (RO) = ...Indexed contents not shown...
    ;   Printers (RO) = #<VLA-OBJECT Printers 2b82cea4>
    ;   ProductCode (RO) = "{90120000-0011-0000-0000-0000000FF1CE}"
    ;   References (RO) = You made an illegal function call.
    ;   Reports (RO) = #<VLA-OBJECT Reports 2b82db4c>
    ;   Screen (RO) = #<VLA-OBJECT Screen 2b82ce14>
    ;   ShortcutMenuBar = ""
    ;   TempVars (RO) = #<VLA-OBJECT _TempVars 2b82d444>
    ;   UserControl = 0
    ;   VBE (RO) = #<VLA-OBJECT VBE 2b898c44>
    ;   Version (RO) = "12.0"
    ;   Visible = 0
    ; Methods supported:
    ;   AccessError (1)
    ;   AddToFavorites ()
    ;   BuildCriteria (3)
    ;   CloseCurrentDatabase ()
    ;   CodeDb ()
    ;   ColumnHistory (3)
    ;   CompactRepair (3)
    ;   ConvertAccessProject (3)
    ;   CreateAccessProject (2)
    ;   CreateAdditionalData ()
    ;   CreateControl (9)
    ;   CreateForm (2)
    ;   CreateGroupLevel (4)
    ;   CreateReport (2)
    ;   CreateReportControl (9)
    ;   CurrentDb ()
    ;   CurrentUser ()
    ;   DAvg (3)
    ;   DCount (3)
    ;   DDEExecute (2)
    ;   DDEInitiate (2)
    ;   DDEPoke (3)
    ;   DDERequest (2)
    ;   DDETerminate (1)
    ;   DDETerminateAll ()
    ;   DefaultWorkspaceClone ()
    ;   DeleteControl (2)
    ;   DeleteReportControl (2)
    ;   DFirst (3)
    ;   DLast (3)
    ;   DLookup (3)
    ;   DMax (3)
    ;   DMin (3)
    ;   DStDev (3)
    ;   DStDevP (3)
    ;   DSum (3)
    ;   DVar (3)
    ;   DVarP (3)
    ;   Echo (2)
    ;   EuroConvert (5)
    ;   Eval (1)
    ;   ExportNavigationPane (1)
    ;   ExportXML (10)
    ;   FollowHyperlink (7)
    ;   GetHiddenAttribute (2)
    ;   GetOption (1)
    ;   GUIDFromString (1)
    ;   HtmlEncode (2)
    ;   hWndAccessApp ()
    ;   HyperlinkPart (2)
    ;   ImportNavigationPane (2)
    ;   ImportXML (2)
    ;   LoadCustomUI (2)
    ;   LoadPicture (1)
    ;   NewAccessProject (2)
    ;   NewCurrentDatabase (5)
    ;   Nz (2)
    ;   OpenAccessProject (2)
    ;   OpenCurrentDatabase (3)
    ;   PlainText (2)
    ;   Quit (1)
    ;   RefreshDatabaseWindow ()
    ;   RefreshTitleBar ()
    ;   Run (31)
    ;   RunCommand (1)
    ;   SetDefaultWorkgroupFile (1)
    ;   SetHiddenAttribute (3)
    ;   SetOption (2)
    ;   StringFromGUID (1)
    ;   SysCmd (3)
    ;   TransformXML (5)
    T
    _$ (vlax-release-object ac)
    2
    _$
    "Potential has a shelf life." - Margaret Atwood
  1. Dbconnect in Windows Vista 64 bit
    By cadconcepts in forum AutoCAD Customization
    Last Post: 2011-03-02, 06:03 PM
  2. DBConnect
    By Gary.182361 in forum AutoCAD General
    Last Post: 2009-06-10, 04:08 PM
  3. dBConnect
    By matthew.carerros in forum VBA/COM Interop
    Last Post: 2006-02-15, 01:55 PM
  4. dbconnect
    By matthew.carerros in forum ATP Course Wishlist
    Last Post: 2006-01-30, 09:13 PM
  5. dbconnect
    By DFlynn in forum AutoCAD General
    Last Post: 2004-06-18, 11:35 AM
