Thread: Grand Stair Problem
    2010-02
    25
    Default Grand Stair Problem
    If I want to create a grand staircase that (from top downwards) splits into two stairs, can I create it by drawing boundaries and risers manually or do I have to create 2 separate stairs that join at some height.
    Attached is a screenshot of the stair being designed and an example jpeg of the concept being replicated. The example jpeg shows a stair that rises and then splits. I want to know how to make a stair that is split and rises into one. (i.e. the reverse of the example jpeg).
    All AUGI, all the time Elmo's Avatar
    2005-04
    South Africa
    959
    Default Re: Grand Stair Problem
    Your going to have to make 2 stair cases. Just create a lvl at the mid landing point so that you can create the second stair starting from that point.
    2010-04
    So. California
    5
    Quote Originally Posted by Elmo View Post
    Elmo, So in other words the intermediate landing would be a new base offset from the lower level ???!? The kitten looks dangerous, better keep a close eye on it.
    2005-04
    South Africa
    959
    You could say so yes.
    Been keeping an eye on that kitten for years. It is dangerous!
  1. 2014: Can you eliminate a column grand total in a schedule but still grand total another column?
    By robinhill833400 in forum Revit Architecture - General
    Last Post: 2020-10-15, 07:31 PM
  2. Stair Problem
    By kathey1 in forum Revit Structure - General
    Last Post: 2011-03-16, 08:29 AM
  3. Stair problem
    By nealmac1978 in forum Revit Architecture - General
    Last Post: 2009-12-07, 10:34 AM
  4. Stair Problem
    By David Donaldson in forum Revit Architecture - General
    Last Post: 2009-11-11, 11:00 PM
  5. 3 Run Stair problem
    By plavallee in forum Revit Architecture - General
    Last Post: 2009-06-22, 02:43 PM
