I wan't to be able to control the way my studs look. When using the framing tool, for some reason the left, right, bottom and top plate get a heavier lineweight and is obscured by the fill pattern. The infill studs on the other hand have the right lineweight and is fully visible. Is it possible to make all studs look the same without being obscured by the fill pattern?
