Hi, here's the story.
on the Curtain wall of myproject, we're having concrete and metal forms projecting beyond the face of the glass. The manufactuer has said they will be hollow, so I made my face based component have a hollow profile as well. now comes the complicated part.
there are some situations where these panels are not only projecting out from the face of the glass behind it, but they also extend beyond the edge of the building. In those situations the panel will be solid, as it would look funny having a hollow cavity visible.
in the facebased family, I made the hollow part, with a void form, constrained with 2 parameters. and side flange thickness, and a face thickness . these just control the size of the void form behind. to create the solid panels, I was thinking of having it use a boolean type of equation...
for example
if panel (solid) then (face depth = 0 ) { so that there is no void being cut out }
else ( face depth = default ) { the standard void gets cut out making it hollow }
"solid" would then be a yes/no check box for them in the properties window.
I thought this would be more elequant, as it would still be the same family the design team is familiar with, it would just have another feature.
is this a fruitless endeavor, and should I just make a whole new family that doesn't have the void form at all ?
suggestions .. tips please .thanks.
