Anyone know of an easy way to turn autocad files into a Bitmap file or Jpeg.
Try the export command. You can export your drawing to a .BMP that way.
-Nathan
if you need a high quality image you'll probably want to set up a plotter for image export thru the "Add-A-Plotter Wizard".
Hi
Please note I've *moved* this thread from the CAD Mgmt. General Forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
Thanks, Mike
Forum Moderator
Hi
Check out the following Technical Documents on the Autodesk web site under the Knowledge Base section -
ID: TS31644 - Raster file formats supported by HDI raster output driver
ID: TS18165 - Using AutoCAD 2000 to create a raster file with a white background
ID: TS71618 - Create and view raster images in AutoCAD®
ID: TS37856 - Changing the background color of raster images
ID: TS55657 - Understanding dpi resolution with the Raster File Formats HDI plotter driver
ID: TS67583 - Export drawing as JPEG file from AutoCAD® or AutoCAD LT®
Have a good one, Mike
