Results 1 to 10 of 10
Thread: Plus/Minus Symbol
    2004-08
    Syracuse, NY
    631
    Default Plus/Minus Symbol
    This may be a simple question, but here it goes.
    Is there a way to enter a plus/minus symbol in dimension strings or level tags. As architects, we all know that existing dimensions are not an absolute.
    I tried to input it as +/- but keep getting this message "enter a value or a formula starting with '='. Is there no way to do this? I miss the %%p that A*&^)$D uses.
    Jason Coe, Architect & Cadd/BIM Lead
    Beardsley architects + engineers
    Auburn, New York
    ____________________________________________
    "Nothing happens by chance and coincidence is when God wishes to remain anonymous"
    http://revitecture.blogspot.com
    All AUGI, all the time BillyGrey's Avatar
    2004-04
    in a calm assertive state
    638
    Default Re: Plus/Minus Symbol
    Right Click your dim string, select properties, then you will prompt into a dialog box and be given the option of adding a prefix and a suffix.
    HTH
    Bill
    2004-08
    Syracuse, NY
    631
    Thanks for pointing that out to me Bill. I must have overlooked that. The elevation/level tags do not have the same option though. These are the ones that I am struggling with to display the +/-. Any suggestions.
    Auburn, New York
    2004-04
    638
    Hey Jason,
    You can create custom annotation symbols real simple:
    Go:
    File/New/Family/Annotations/Level Head.rft
    That is where you create a custom level bubble...
    You simply draw yur bubble, and add two labels, (that are dynamically linked to the name of your level, and the height of your level). You can position those labels, then place a text suffix in front of the "Level" label. Save the file, then load it into your project.
    I also created one you can open and study. Just be aware that it only works for text to the left of the datum because that is how the suffix is placed. If you want to be able to place the bubble on both sides, just create another one and correct the text possition. You may also have to edit the placement of the labels to orient correctly for your font size, naming conventions, etc.
    I think there could be a better way do this, but until someone chimes in, I hope this gets you where you need to be.
    2004-08
    Syracuse, NY
    631
    Thank you Bill. This is exaclty what I was looking for. I think this is something Revit should address in the future - it could be as simple as a yes/no parameter that one could toggle on/off as needed.
    Auburn, New York
    Active Member frame's Avatar
    2003-09
    Factory
    94
    Not obvious, but the functionality is available.
    Make a new level head family and change the formating to not use project settings.
    Then you can check the checkbox "use "+" for positive values"
    See sample file
    2004-04
    638
    Thanks frame
    b
    2019-01
    Bill,
    I do not have that option. Where?
    Does not show up in my properties.
    2001-12
    Irvine, CA
    7,399
    FWIW, congrats on your first post. You've just replied to a thread that is 14 years stale though.
    2005-06
    in the upper right corner
    3,104
    Quote Originally Posted by jacobburski777508 View Post
    Bill,
    Good question.. it doesn't show up in properties for me either.. it must have been an option in Revit 14 years ago?
    But if you simply double click the dimension text it should get you to the dialog where you can add suffix, prefix, text above or below or whatever..
    HTH
    Ted
    ____________________________________________________________________ ________________
    Windows 7 Professional
    AutoCAD 2017 - REVIT 2017 - Inventor Professional 2015 (when I can)
  1. Plus or Minus Sign
    By TipToeUp2 in forum Revit - Student Support
    Last Post: 2015-09-07, 06:14 AM
  2. 2015: Add plus and minus symbol to dimension in Revit 2015?
    By jtakata341417 in forum Revit Architecture - General
    Last Post: 2015-01-09, 10:23 PM
  3. Revit to Max (minus mental ray?)
    By Dan C in forum Revit - Plotting/Printing/Exporting
    Last Post: 2009-09-17, 11:59 AM
  4. Plus/Minus
    By Alek Sutulov in forum Revit Architecture - General
    Last Post: 2003-05-31, 12:52 AM
