Has anyone experienced problems when doing solar studies / shadow studies for various times of day in the month of December?
The problem is, we are finding that the shadows seem to get 'inverted' so that the building becomes shaded as if in shadow, but the surrounding ground plaen turns white or better put, not in shadow.
The workaround is, if the daylight savings option is checked, the settings seem to work as normal. Technically we don't have daylight savings in December but the setting affects all of the views, which means we may need to check to the setting for a batch of views, and then uncheck it for another batch of views. If it is checked, we also need to go and set our day times back one hour. This all seems very 'un-revit'... Am I looking at this the wrong way?
Any help very much appriciated in advance...
