The Urban Sidewalk Sub-Assembly datum links do not work when you attempt to create a datum surface from them.
I need a sidewalk assembly that has horizontal and vertical targetting parameters for inside boulevard and back of sidewalk.
Finally, the datum links need to acuratly model the datum surface..as apposed to what the out-of-the-box sub-assembly does... incorrect triangulation.
Any ideas people? I tried making one completley out of geneeric links..and it almost worked..but a couple of the sections did not work..even though those corridor regions had the exaxt same input parameters as the regions that did work.
