ordengate
Is it possible to do this? Currently some of my blocks have attributes that are on layer 0, all bylayer. In some versions of the same block, they're on a new layer, so naturally I want the attribute to be on a new layer as well. (for instance, a panel board block with the ID at the top, and rating at the bottom. Text is one line thickness, panel is another, hence the need for two layers.)
Is there a way to quickly change the attributes from one layer to another like matchprop? A lisp routine previously written perhaps?
