Thread: Changing the color of the Columns that go up from the level
    2010-11
    6
    Default Changing the color of the Columns that go up from the level
    Hi all,
    Is there any way to change the colors of the columns that goes up from the current level.(in the plan view) Actually these columns shown thick, and the normal columns shown thin. But if the view is changed to "thin lines" then that view disappears, and these columns are seen as normal columns.
    Thanks.
    2007-10
    26
    Default Re: Changing the color of the Columns that go up from the level
    Adjust the Object Style or Visibility Graphics of the columns so that the projection and cut lines are different colors. The cut lines would control the look of those columns that go up from the current level. The projection style would control the other columns.
    Ben Buergler
    EMC Structural Engineers
  1. Changing the 0' - 0" level datum to a different level
    Last Post: 2011-01-20, 07:03 PM
  2. HSS Hollow Columns not working with base level constraint
    By brinddd in forum Revit Architecture - General
    Last Post: 2010-01-25, 06:59 PM
  3. Columns placed on wrong level
    By cphubb in forum NavisWorks - General
    Last Post: 2009-02-20, 06:18 PM
  4. Changing Associated Level
    By anthony.doyle in forum Revit - Platform
    Last Post: 2007-11-20, 11:16 PM
  5. Columns insert at a 0 level and not my floor level
    By wingman in forum Revit Architecture - General
    Last Post: 2005-04-25, 07:25 PM
