Thread: Skylight with curb
    2010-07
    New Orleans
    34
    Default Skylight with curb
    I want to create a skylight with a curb. The bottom of the curb should snap tp the slop of the roof, but the top of the curbs, as well as the skylights need to be horizontal. how do I do this?
    2009-01
    45
    Default Re: Skylight with curb
    Use walls for your curbs, attach the bottom of the walls to the roof, and then place your skylight on top. If you use the tops of these walls as the reference plane for inserting your skylight, you can adjust your curb heights with the wall height controls and won't have to move your skylight after.
    Dan Sawyer,
    Kelowna, BC
    2010-07
    New Orleans
    34
    Dan, thanks a lot for your reply. Your solution is very good.
    I am still curious though.
    Is there any way to have a family intillegent to do this?
    2009-01
    45
    My initial reaction would be no, but I may be wrong. There are just too many variables that your family would have to consider; roof slope, skylight size, curb heights, and on it goes. If you could create a family like that, I'd buy it from you.
    Dan
    2006-01
    4,516
    Yes, you can. But it wont figure out ALL of that. You have the option to make a family "Always vertical" or not. if its "Not" it will orient itself off the roof slope. If its "always vertical" the walls will protrude straight up. But it doesnt work out so well when you model in things like flashing, etc.
    The above post is by a user not frequenting the site. Questions regarding post:
    Send to: aaron@aaronmaller.com (include text of post). Thanks.
  1. Dome Skylight
    By brede.207016 in forum Revit Architecture - General
    Last Post: 2009-04-28, 06:46 PM
  2. I need 1 skylight shown in RCP and RP
    By nsinha73 in forum Revit Architecture - General
    Last Post: 2008-11-14, 10:05 PM
  3. Round skylight
    By agu in forum Revit Architecture - Families
    Last Post: 2007-10-26, 12:08 PM
  4. Skylight Plan Rep
    By jcoe in forum Revit Architecture - Families
    Last Post: 2006-03-21, 05:58 AM
  5. Pyramid skylight on the fly!
    By SCShell in forum Revit Architecture - Tips & Tricks
    Last Post: 2004-06-12, 06:17 PM
