Thread: truncated cone
    2005-04
    18
    Default truncated cone
    I need to draw a cone shape with the top cut off. Bottom diameter is 1", top is 1/8", height is 1/2".
    0,0,0 The Origin
    8,025
    Default Re: truncated cone
    and?
    What do you want? plan, elevation, oblique / isometric view?
    You can't create 3d surfaces or solids in acad LT though you can make a wireframe model.
    If you start with -
    Command: c
    CIRCLE Specify center point for circle or [3P/2P/Ttr (tan tan radius)]:
    0,0,0
    Specify radius of circle or [Diameter]:
    0.5
    Command:
    c
    0,0,0
    Specify radius of circle or [Diameter] <0.5000>:
    0.0625
    Command: m
    MOVE
    Select objects:
    [pick the small circle]
    1 found
    Select objects:
    Specify base point or [Displacement] <Displacement>:
    [pick any point]
    Specify second point or <use first point as displacement>:
    @0,0,0.5
    Command:
    _-view
    Enter an option
    [?/Delete/Orthographic/Restore/Save/sEttings/Window]:
    _swiso [to get a better view]
    Regenerating model.
    Then you can draw 4 lines between the quadrant osnap points on the circles. If you want more than 4 lines, you'll need to use the divide command on each circle to place points to snap to. it might be best to break each circle first though.
    You might end up with something like this but it will not hide.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2005-04
    18
    I will try this John, thank you for the info.
  1. Import Units are Truncated
    By jason.combs in forum NavisWorks - General
    Last Post: 2010-02-04, 03:54 PM
  2. Railings - Truncated
    By d.stairmand in forum Revit Architecture - General
    Last Post: 2006-09-20, 03:26 PM
  3. Truncated cone surface
    By dhurtubise in forum Revit Architecture - General
    Last Post: 2006-05-13, 03:01 AM
  4. Does anyone have a pattern for Truncated Domes?
    By hdjohnson in forum Revit Architecture - Families
    Last Post: 2005-07-13, 05:15 PM
  5. upside down truncated cone floor?
    By john.84851 in forum Revit Architecture - General
    Last Post: 2005-03-28, 06:15 PM
