Thread: Revit 2011 to Impressions 3
    2005-04
    230
    Question Revit 2011 to Impressions 3
    Hi there.
    Can someone share on how they experiencing the workflow between Revit 2011 and Impression 3. I seem to be having many teething problems with the process of getting good results… Wrong scales, wrong lineweights etc. etc.
    Craig
    2005-04
    230
    Default Re: Revit 2011 to Impressions 3
    Hi again.
    Possibly it may help at this stage to explain my process/workflow so far...
    From Revit I export to DWG.
    As there is no longer an Export to Impression option in AutoCad 2011 there is no point in going into AutoCad 2011 at this stage.
    What I do, do however is take the PCP file created with the exported DWG and use it in AutoCad to create a CTB for the DWG.
    I then in Impression go to document setup and set the document up to be identical to my Revit Sheet.
    I then import the DWG file into Impression using the DWG Import Wizard
    Straight away I am faced with some problems...
    1) Scale is wrong I need to go and manually edit the scale in the layers dialog.
    2) As soon as I apply a Global Stoke to the drawing all dotted / dashed lines become solid.
    Possibly someone else has had similar problems with workflow between Revit and Impressions who could shed some light on the subject! Simply all I am wanting to do is this... Take a plan from revit into Impression and give it a sketchy look, while still retaining scale / line weights / and line patterns as per my revit drawing.
    Any ideas?
    Craig
  1. FBX Woes from Revit Arch 2011 to MaxDesgin 2011
    By r.grandmaison in forum 3ds Max - General
    Last Post: 2010-06-29, 02:54 AM
  2. Is AutoCAD 2011 included with Revit Structure Suite 2011
    By durentech in forum Revit Structure - General
    Last Post: 2010-06-24, 01:27 AM
  3. Revit 8 Impressions?
    By aaronrumple in forum Revit Architecture - General
    Last Post: 2005-05-09, 05:31 PM
