Thread: Problem with glazing position in sloped glazing roof
    2004-06
    Memphis TN area
    7,048
    Default Problem with glazing position in sloped glazing roof
    I have a curtain panel type that is offset 1 1/4" for use in front-glazed curtain walls. I just created a sloped glazed skylight using 2x4" rectangular mullions and that offset sloped glazing, but the glazing is showing up offset DOWN towards the bottom of each mullion. Is that the normal behavior with sloped glazing?? Seems very odd that a positive value for offset on a system panel would make said panel move down on sloped glazing.
    2006-09
    The Kingdom of Denmark
    560
    Default Re: Problem with glazing position in sloped glazing roof
    I´m afraid that it´s normal (but unwanted) behavior - Have had this isue several times, and always end up with a custom panel for the sloped glazing
    2010-04
    7
    I've also just come accross this problem. there is a bit of a trick easily resolving this.
    First you have to creat a duplicate Sloped glazing type for the flipped side.
    Then create a duplicate of the system panel for the glazed roof - set the offset to a negative figure.
    Apply that glazed panel to the to the defult for the sloped glazing type.
    Sorted
    Autodesk should probably look into resolving this properly though...
    2015-12
    Vancouver, BC Canada
    3,753
    Not sure if this has been resolved Patricks but since Number 7 replied...
    Check out a couple of threads along this line
    http://forums.augi.com/showthread.ph...azing+location
  1. 2013: Sloped Curtain Glazing Roof: Grid Angle
    By seanmiller09593080 in forum Revit Architecture - General
    Last Post: 2013-04-15, 04:20 AM
  2. Problem with Sloped Glazing Roof Panels
    By dvanburen in forum Revit Architecture - General
    Last Post: 2006-11-07, 02:43 AM
  3. Sloped Glazing roof
    By Mark Vorstenbosch in forum Revit Architecture - General
    Last Post: 2006-02-02, 06:10 AM
  4. Sloped Glazing Grids Don't Line Up at Roof Ridge
    By artitech in forum Revit Architecture - General
    Last Post: 2005-05-05, 11:45 AM
  5. Steanding Seam Roof/ Sloped Glazing Problem
    By Allen Lacy in forum Revit Architecture - General
    Last Post: 2004-06-04, 02:52 PM
