Thread: scale for Autodesk Material library maps
    2010-11
    2
    Default scale for Autodesk Material library maps
    I am new to Max and started to use it to create renderings of architectural models imported from Revit.
    I am using a shake roofing material from the Autodesk Material Library and need to adjust the scale of the map to look right.
    What is the width and height scale based on ? I assume it is the setting for a 12"X12" area, so if I set width and height to 12" it is 'to scale'.
    Is my assumption correct ?
    Also, is there any way to adjust the size of the sample ball in the material editor?
    The ball seems to be huge since the material pattern appears very small.
    Thanks for any input.
    2011-03
    Default Re: scale for Autodesk Material library maps
    Quote Originally Posted by wrif View Post
    What is mental ray? How to install mental ray? How to apply?
    thanks
  1. Material Maps transfer with 3D PDF's
    By me.simonyoung528218 in forum Revit Architecture - General
    Last Post: 2011-08-02, 12:15 AM
  2. Material Library
    By mjm.158454 in forum Revit Structure - General
    Last Post: 2011-02-03, 02:38 PM
  3. Seeing textures and material maps in views?
    By sfraney in forum Revit Architecture - General
    Last Post: 2006-12-28, 02:28 PM
  4. Library, Material Library that is...
    By dsw98 in forum Revit - Rendering
    Last Post: 2006-01-16, 03:26 PM
  5. Library, Material Library that is...
    By dsw98 in forum Revit Architecture - General
