Results 1 to 9 of 9
Thread: Text Mask looses text
    2010-07
    25
    Default Text Mask looses text
    When I use the text mask command on text, the text disappears. I try to select text to bring to front but no text is found to be gripped. Am I missing a setting?
    2004-08
    Hartford, Michigan
    3,086
    Default Re: Text Mask looses text
    Quote Originally Posted by ccook79 View Post
    are you using the express tool textmask? or applying a text mask property? Have you tried a regen? or sending the mask to back, then bringing the text and mask to front?
    Christopher T. Cowgill, P.E.
    WIGHTMAN & ASSOCIATES, INC.
    ENGINEERING <> SURVEYING <> ARCHITECTURE
    AutoDesk Infrastructure Design Suite Premium 2013 x64
    Windows 7 Pro x64
    2010-07
    25
    Quote Originally Posted by ccowgill View Post
    express pull down menu, yes I've tried sending to back.... front but no text appears to be there
    2004-08
    Hartford, Michigan
    3,086
    are you attempting to use it on annotative text? Try changing your annotation scale, then switching back.
    Windows 7 Pro x64
    2010-07
    25
    wow that was it...turn off annotative and it worked....interesting...thanks!
    2004-08
    Hartford, Michigan
    3,086
    you're welcome.
    A lot of the express tools dont play well with newer objects, mostly I think it is because they use entmod (or something like that) and that doesnt play well with the annotative objects, that and express tools are in need of a complete overhaul.
    Windows 7 Pro x64
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    1,901
    If your using mtext I would recommend using the background mask properties of the mtext instead. Unlike the express tools text mask, the background mask will change sizes with the annotative text.
    Jeff Paulsen
    0,0,0 The Origin
    8,026
    Quote Originally Posted by jpaulsen View Post
    and it it's text, use the express tool to convert to mtext. MText masking generally seems "better" than the other sort.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2010-07
    25
    yea, background mask is a new one for me.
    Thanks!
  1. text mask deletes text
    By gingermick in forum AutoCAD Annotation
    Last Post: 2010-02-23, 02:55 AM
  2. Text and Mask
    By archie.manza in forum AutoCAD Tips & Tricks
    Last Post: 2009-10-08, 07:17 PM
  3. Replies: 8
    Last Post: 2007-07-03, 04:25 PM
  4. Updating Text Mask once Text has been edited
    By r_soula in forum AutoCAD General
    Last Post: 2007-06-05, 03:05 AM
  5. Text Mask
    By Andrew.Mills in forum ACA General
    Last Post: 2004-10-12, 09:33 PM
