Thread: Cable Tray - Hatch Patterns
    2010-08
    6
    0 Did you find this post helpful? Yes
    Default Cable Tray - Hatch Patterns
    We just rolled out Revit MEP 2011 and I have a quick question about the new cable tray feature. Is there a way to apply a hatch pattern to the surface, or modify the material? I see that they're system families, so the "edit-ability" is limited. We currently use a custom made family that looks great on the drawings, but cumbersome to use. The new command would work great if we could only add a surface pattern to it.
    I would appreciate the advice. Thanks.
    2004-06
    Port Moody, BC
    346
    Default Re: Cable Tray - Hatch Patterns
    You can use a Filter to find the cable tray then apply a surface pattern to it, finding all sizes greater than zero would get them all.
    The Silent Type
    2015-10
    5
    Can you please explain how exactly you assign hatch patterns to cable tray in revit(step by step), i am new to revit previously we did our projects in AutoCAD now we are moving to revit. attached is the cable tray hatch i want to assign to my cable tray with red color.
    Regards
    Ali
    2010-04
    Perth, Australia
    116
    The easiest way to begin with is to use filters.
    Go to Visibility Graphics and the filters tab.
    Create a new filter for cable trays AND fittings with whatever filter you want to aply (say service type = power)
    For this filter you can add a pattern for the projection/ surface, including any colouring you want.
  1. 2013: Cable Tray Hatch Pattern
    By ah_heras420442 in forum Revit MEP - General
    Last Post: 2013-09-28, 08:29 AM
  2. Cable Tray Types
    By RevitNinja in forum Revit MEP - General
    Last Post: 2011-09-13, 04:33 PM
  3. Runners for cable tray
    By Jimbob in forum Revit MEP - General
    Last Post: 2011-05-04, 02:04 PM
  4. cable tray - MEP net api
    By morff89 in forum Dot Net API
    Last Post: 2010-07-05, 02:06 PM
  5. Cable Tray
    By satish in forum Revit MEP - General
    Last Post: 2010-05-06, 09:02 PM
