Thread: Model Space Viewports
    2001-02
    Allentown, PA
    207
    Default Model Space Viewports
    Is it just me or did Autodesk do away with the line that used to show up when you had multiple model space viewports?
    Is there a way to turn it on and off that I don't realize?
    See attached jpg that shows two model space viewports withouth the line seperating them.
    0,0,0 The Origin
    8,570
    Default Re: Model Space Viewports
    It must be you.
    Sorry, don't know the answer.
    2010-08
    11
    The Modelspace viewport borders are assigned the same color as the Modelspace crosshairs.
    Normally, "white" crosshairs will automatically be displayed as black on a "white" background (and vice versa) but other elements that change with the crosshairs such as the aperture box, crosshair XYZ markers, and apparently the modelspace viewport borders, do not, and are therefore "invisible" if the crosshairs and the background are the same color.
    Options > Display > Windows Elements > Colors
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    If the viewport layer is frozen the lines disappear. Doesn't affect the display of the viewport.
    0,0,0 The Origin
    8,570
    That's paperspace, not modelspace.
  1. Merge all viewports from model space to paperspace
    By lorne.bourdo.152516 in forum ACA General
    Last Post: 2012-04-26, 07:36 PM
  2. How to include drawings in Model space into Viewports
    By dlauxx in forum AutoCAD Annotation
    Last Post: 2009-03-12, 02:03 AM
  3. Replies: 3
    Last Post: 2007-04-21, 05:38 AM
  4. viewports in model space
    By dzatto in forum ACA General
    Last Post: 2007-04-13, 09:00 PM
  5. Model Space Viewports
    By Merlin in forum AutoCAD General
    Last Post: 2006-02-10, 01:38 PM
